Battery ground cable
Old Nov 3, 2021 | 08:15 PM
Harleyrocker's Avatar
Harleyrocker
Default Battery ground cable
My friends dad has a 1980 corvette with 45500 miles. Hes been sick a long time and the family wants me to get it all cleaned up and running. Its been sitting on there carport for several years and only started on occasion. My first problem is the battery ground cable that goes through the floor through the rubber plug is bad. I cant find one that looks like or has the new plug on it . Here is a picture of it .
Old Nov 3, 2021 | 08:39 PM
Mrvettenick's Avatar
Mrvettenick
Use wd40 and slide that boot off the old cable, Then slide it on the new one.
Old Nov 3, 2021 | 10:32 PM
speedreed8's Avatar
speedreed8
Or $34
Old Nov 4, 2021 | 06:52 AM
Harleyrocker
Why does mine not have the second small ground wire. Would i just screw it to the frame as well. Thanks tor the link
Originally Posted by speedreed8
Or $34
Old Nov 4, 2021 | 10:32 AM
lakerider57's Avatar
lakerider57
I have a 1980, I remember the small wire connecting to a terminal on the right side of the battery box as such:
I no longer use this wire in my current setup.
Richard
Old Nov 4, 2021 | 03:42 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
The ground wire attaches to the metal bulkhead that is behind the seats.
The terminal block on the left side of the battery in the battery box is for the positive battery cable. Do not hook your ground wire to that terminal block! The terminal block is the connecting point from the red charge wire coming from the alternator and going to the battery.
Old Nov 4, 2021 | 03:47 PM
interpon's Avatar
interpon
for now if the old one didn't have one. Leave it..!!!!! it is probably a universal add.. to carry one cable.. my 79 does not have it.. not sure 80
as stated above do not attach to pos..
Old Nov 4, 2021 | 04:30 PM
lakerider57
Mattoonvette, thanks for the clarification on that one,
Richard
Old Nov 4, 2021 | 06:00 PM
7t9l82's Avatar
7t9l82
I had my local interstate battery store make me a bigger ground cable just because I could lol
Old Nov 4, 2021 | 08:03 PM
MattoonVette
Richard
My pleasure sir!
Old Jun 1, 2024 | 10:13 PM
lvacordian's Avatar
lvacordian
5th Gear
how exactly does the ground wire attach to the steel bulkhead behind the seats? I don’t see a bolt or terminal for the negative battery cable to attach to. Is there supposed to be a terminal? I have a 1980 L-82
Old Jun 1, 2024 | 10:43 PM
Mrvettenick
The negative battery cable goes through the bottom of the battery box and attaches to the frame crossmember right below the battery. There should be a hole in the frame right below the battery.
Old Jun 1, 2024 | 11:00 PM
Eliredandblack's Avatar
Eliredandblack
Be sure to clean the area where the new cable attaches to the metal frame, you want to have superior connectivity.
Old Jun 2, 2024 | 12:21 AM
lvacordian's Avatar
lvacordian
5th Gear
[QUOTE=Mrvettenick;1607860873]The negative battery cable goes through the bottom of the battery box and attaches to the frame crossmember right below the battery. There should be a hole in the frame right below the battery.[/QUOTE
Thanks for your reply. My negative battery cable has two ground connections like the one in the picture. The main grounding point is like you mentioned under the battery box to the frame. That connection is already in place but the shorter wire is not. A previous poster said that the shorter wire should be connected to the steel bulkhead behind the seats.
I’m trying to determine where exactly on the bulkhead the shorter black wire connects to since I don’t see any terminal connections or bolts on the bulkhead to connect to. Do you know?
Does the shorter black wire also connect to the same grounding point that the main connection does? If so then why have an additional wire?
I have the factory service manual and the assembly manual and I was surprised not to see any information on this. Thanks very much for your help.
Old Jun 2, 2024 | 03:12 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Your manuals do not have any information on this shorter wire as it is NOT factory. Not certain about the very last of the C3's. Knowing the year of your car could be helpful.
But I am certain on the earlier cars, pre 1980 for certain. This extra wire does not exist.
Old Jun 2, 2024 | 09:25 AM
Mrvettenick
That's probably a multifunctional cable meant for multiple cars. All they did was add the grommet to make it fit. I would either cut it, or cover the end with electrical tape, so it doesn't touch the positive connections when you move things around.
Old Jun 2, 2024 | 09:38 AM
gjohnson's Avatar
gjohnson
You dont need the small wire. Chop it
To Battery ground cable
Old Jun 2, 2024 | 10:36 AM
lvacordian's Avatar
lvacordian
5th Gear
Thank you. I have a 1980 L-82
Old Jun 2, 2024 | 03:17 PM
MattoonVette
Mine is an 81 and there is a small ground wire that comes off the negative battery cable and is attached to the bulkhead right of above the armrest bracket. There is also a ground wire coming out of the harness that attaches to that same grounding point. I wouldn't cut it if it were mine. In my opinion, the more ground wires the Vette has the better.
Old Jun 2, 2024 | 03:27 PM
MattoonVette
It is factory on the 81 and more than likely on the 82. It may have been an additional ground point for the CCC on the 81 or part of the ETR type radio. The ones with the ETR radio, 81 and 82, did have some different wiring than the other earlier Vettes.
