Thug bug
Old Nov 10, 2021 | 06:43 PM
timsyelloc7's Avatar
timsyelloc7
7th Gear
Default Thug bug
I just got an 82 vette that has a thug bug alarm. Keypad to start. Anyone know where I can get a diagram so I can remove it?
Old Nov 11, 2021 | 07:25 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I understand they were made by Precision which is now Scytec. Try contacting them. Just a shot...
https://scytec.com/support/contact-support/
Old Nov 11, 2021 | 07:40 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Original copies of the wiring diagram are available from Papadana on this site.......there is a thread here in tech, just ask and he will send you one for free.A must for your files.
You can reverse engineer it with the right diagram.
Jebby
Old Nov 11, 2021 | 02:33 PM
timsyelloc7
7th Gear
I contacted Syntek.. No help.
Jebby: I'm new to this forum so my search skills may be lacking. I searched c3 tech performance for Papadana and did not get a hit on a thread as you suggested for thug bug. O nly hit was this thread...
any other ideas?
​​​​​ It would be wonderful to get a schematic
Old Nov 11, 2021 | 04:36 PM
riverracer au's Avatar
riverracer au
try asking in this thread, he has wiring diagrams for just about everything to do with vettes
https://www.corvetteforum.com/forums...or-anyone.html
Old Nov 11, 2021 | 05:06 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
any other ideas?
I spelled it wrong….papawana is his name…..
Anyway….the link is above!
Jebby
Old Nov 11, 2021 | 07:35 PM
timsyelloc7
7th Gear
Thanks very much for the help. I got in touch with Papawana and he sent diagrams
Old Nov 11, 2021 | 08:07 PM
interpon's Avatar
interpon
I had luck and only 2 pinched tapped wires from oem harness….
https://www.corvetteforum.com/forums...preciated.html
Old Nov 12, 2021 | 09:07 AM
Jud Chapin's Avatar
Jud Chapin
Yikes!
Old Nov 12, 2021 | 09:51 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
There are no words to accurately describe my woe and depression after seeing this.......
Many other ways to secure an automobile without that terrible pile of ****......
For Instance, a switchable 30a relay for the 12v PWR connection at the HEI. Simple and effective.....
Jebby
Old Nov 12, 2021 | 11:28 PM
bluthundr's Avatar
bluthundr
Do you get paid by the splice or something?
Old Nov 16, 2021 | 10:20 AM
ctmccloskey's Avatar
ctmccloskey
I worry when I am driving my C3 in a bad area (like near the Capitol in D.C.). Is there a way to put a "Time Delay" shut-off on the engine so the car thief would get go about a block before it shuts down? This way you have a chance to hide or get help before they find you after the car-jacking. If the car is being car-jacked I would like to be sure they don't get far so I would like a button or switch that when pushed that will kill the engine in 60 seconds after they take it (IF they can drive a 4 speed).
If I saw a pile of wiring like that I would not buy the Corvette. That car is "Bubbafied" and undoing the damage to the wiring system might take a pro to figure it all out.
Having a "Convertible" means Nothing is "sacred or private" anymore. People reach down to my interior, touch the dashboard and touch parts and have even taken things like the original 1968 Radio control ***** I had stolen from my Corvette while at Corvettes@Carlisle by a fellow Corvette owner who coveted the original ***** for the radio. Another time some fool stole my Handicapped Parking Permit off my rear view mirror. For some reason people think since it is open it is available to take should you want it.
I am now leaving nothing valuable available to be lifted out of the Interior. I also leave the doors unlocked so they won't cut up the convertible top.
Old Nov 16, 2021 | 10:28 AM
Jud Chapin's Avatar
Jud Chapin
I used to disconnect the battery when in a questionable area. Here's something that's better. A thief is not going to take the time to find out why the car won't start.
https://www.corvettecentral.com/acce...-switch-171255
Old Nov 17, 2021 | 07:46 PM
wilcar's Avatar
wilcar
A good delay to use would be a couple rounds fired out of your 9mm, .45, or 12 ga scatter gun!!
Old Nov 19, 2021 | 07:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wow what a mess!!
Old Nov 20, 2021 | 07:18 PM
wilcar's Avatar
wilcar
Jebby
Great idea! Wilcar
Old Dec 4, 2021 | 05:28 PM
timsyelloc7
7th Gear
Default Thug bug updated
I was able to remove the thug bug. Once I found the brain (tucked inside fender) i was able to trace the wiring. As I expected it tapped into the tach wire on the HEI distributor. Turns out it was not as difficult as I thought.
To Thug bug
