Rear shock removal tool
Old Nov 19, 2021 | 10:31 AM
fake's Avatar
fake
Default Rear shock removal tool
Rear shock removal tool what can i use to remove?
Old Nov 19, 2021 | 10:43 AM
kansas123's Avatar
kansas123
I used 2 open end wrenches on the top, I'm guessing that's the end that's causing problems? Mine's a '72
Old Nov 19, 2021 | 03:01 PM
Mooser's Avatar
Mooser
Soak everything in PB blaster or whatever you like
If you can get a coupler nut (the ones that are like an extra long nut) and then a short bolt of the same thread. If not then a normal nut but be careful. Thread is 5/8 x 18.
Thread the nut on a bunch of threads and then thread the other bolt in until it bottoms out against the end of the shock mount and hit that with a hammer. That way you're hitting the end of the mount rather than loading the threads (shear)
You can put the stock nut on backwards and wind it down with the end and hit that being careful not to bugger the end up
The "tool" is basically a long nut with a cap and it bottoms out on the cap,
M
Old Nov 19, 2021 | 05:13 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
What year is the car are the shocks original ?
Old Nov 19, 2021 | 05:22 PM
interpon's Avatar
interpon
Just to be clear..the shock? Or shock mount?
Old Nov 20, 2021 | 08:48 AM
fake's Avatar
fake
Shock mount, 1977 car
Old Nov 20, 2021 | 09:04 AM
Mooser's Avatar
Mooser
Is it the shock you're trying to get off (use a small pickle fork) or the mount so you can get the strut rod off (see post #3)
M
Old Nov 20, 2021 | 09:34 AM
interpon's Avatar
interpon
post 5 and 8 with summary post 18 to remove shock mount..aka strut bar mount
pic?
https://www.corvetteforum.com/forums...od-advice.html
Old Nov 20, 2021 | 10:36 AM
ralphspears
Banned Scam/Spammer
This is a shock mount removal tool you screw it on till it bottoms out then hit it with a sledge hammer and the shock mount pops right out
Old Nov 20, 2021 | 01:06 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
What is it? Actually a tool or just a long nut? Were did you get it?
Old Nov 20, 2021 | 01:34 PM
Mooser's Avatar
Mooser
they are basically just a long nut that either had a blind tapped hole or a plate welded onto the far end. It's not rocket science but all you're trying to do in be able to pound on the end without screwing up the thread / mushrooming the end of the bolt.
M
Old Nov 20, 2021 | 02:19 PM
ralphspears
Banned Scam/Spammer
I bought it about 40 years ago it is a tool to remove the shock mount I have used it many times over the years. I just looked in the Paragon catalog they have them for 25.00 rear shock shaft tool removes shock shaft from spindle support the tapped hole in the toll is flat on the bottom so it does not hurt the threads on the shock shaft
Old Nov 20, 2021 | 03:02 PM
0311 jarhead
Thanks Ralph
Old Nov 21, 2021 | 11:45 AM
GTR1999's Avatar
GTR1999
The shock mount tool is the best way to remove them without mushrooming the threaded end but then the knurl on the heads are going to be flat anyway. So you can reuse it with flat knurls or just but a new one. The LH side will tend to turn CW while tightening if the knurl is rolled, you can support it with a 2x4 or pipe wrench when torquing it and it might stay in place but if it moves it will start to roll over the D-Flat in the support leg.
Now being in CT there rust issue comes to play. I have had arms come in with the strut rod still installed because the shock mount was seized to the steel sleeve in the bushing and there was no way oil was going to get to that point to loosen it. If that is the case then you will have to replace more then a shock mount.
Also when the 63 came out, there was no webbing between the legs and it didn't take a year before the revision from 64-82 had webbing cast in between the legs. The point is the legs can bend if hammered on too hard and the mount is seized. I recall buying supports off ebay and when they came in were junk, the legs bent from someone who didn't know how to get out a seized mount.
Old Nov 21, 2021 | 01:22 PM
sunflower 1972's Avatar
sunflower 1972
I used a 3/8 inch NPT pipe cap on mine (about $2.00 at the local hardware store) and a 3 lb. drilling hammer. Came out relatively easy. Fortunately, they were not seized.
Old Jul 5, 2025 | 10:46 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
Can someone please explain to me how when using this tool, you aren't putting the impact of each hammer strike directly on the threads of the shock mount itself?
When you thread the tool all the way down until it bottoms out, are there still some threads showing on the shock mount?
Old Jul 5, 2025 | 11:34 PM
carriljc's Avatar
carriljc
Big Monza Red
Try using a pickle fork. I got mine off and they had not been off for decades. Less thread threatening tribulations.....
see here:
https://www.corvetteforum.com/forums...post1608166230
Old Jul 5, 2025 | 11:57 PM
MelWff's Avatar
MelWff
The tool bottoms out so the impact is on the end of the mount but the mount end is protected from damage.
Old Jul 8, 2025 | 02:52 PM
alt66's Avatar
alt66
Seems to me I seen some where that a pipe thread cap will work from the local hardware store.Sorry looks like someone already suggested that.
To Rear shock removal tool
