spark plugs
Old Nov 21, 2021 | 10:11 PM
garykuter's Avatar
garykuter
Default spark plugs
I know there are different spark plugs for my 77 vette with the 350 block. I also have the long tube headers on it. I would like a plug that is the best as far as performance . What would you recommend? Thank you.
Old Nov 21, 2021 | 10:15 PM
76strokervette's Avatar
76strokervette
Ngk
Old Nov 22, 2021 | 02:33 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Which heads? Compression ratio?
If your engine is mostly stock. Just look them up on the chart. And yes. NGK.
Old Nov 22, 2021 | 04:42 AM
garykuter's Avatar
garykuter
Far as I know, block is stock. Has a mild cam, edelbrock manifold, 600 carb. I just put 390 gears in the rear end. yes, stock heads. Its the L82 model.
Old Nov 22, 2021 | 04:52 AM
4-vettes's Avatar
4-vettes
Header's won't change plug requirements. Just run a good quality spark plug. Myself, I've had the best luck with NGK. I don't have stock heads on my 77 so I won't recommend the plugs I run. Simply look them up in there replacement charts.
And my condolences on the factory heads.
Old Nov 22, 2021 | 05:24 AM
garykuter's Avatar
garykuter
What can I say, I just got the car a few months ago. Haven't done the heads or anything else yet except the gears. Thanks for the info.
Old Nov 22, 2021 | 09:31 AM
REELAV8R's Avatar
REELAV8R
I ran the NGK UR45 with my headers when I ran the stock/cast iron heads. Worked good. They're a little hot, depends on your driving. You could always try UR55 if you have issues. But with low compression engine IE 8.0:1 or so theUR45 worked good at my altitude. If you're at or near sea level the UR55 may be more appropriate.
https://www.ngk.com/ngk-2248-ur55-v-power-spark-plug
Old Nov 22, 2021 | 02:09 PM
Sayfoo's Avatar
Sayfoo
I've found that the cheap, copper plugs run just as well as any high $$$ plugs. They may not last as long, but with unleaded gas, they can still go 20k miles.
The right heat rating and correct length is more important.
Ok, well, I don't buy Champion, as they had major quality control problems in the past.
Old Nov 22, 2021 | 07:31 PM
wilcar's Avatar
wilcar
So the UR55 is one range hotter?
Old Nov 22, 2021 | 07:49 PM
fake's Avatar
fake
Buy your plugs at Rock Auto and i run NGK in my L-82 they never foul compared to the AC Delco . The 77 i have never shows traces of any fouling with the NGK.
Old Nov 22, 2021 | 08:20 PM
MelWff's Avatar
MelWff
you make no mention if you have a clearance issue because of the headers. If you do, look at Accel, they make short plugs for header applications.
Old Nov 22, 2021 | 11:18 PM
REELAV8R's Avatar
REELAV8R
one range colder.
NGK lower number is hotter higher number is colder
https://www.ngk.com.au/technical_info/heat-range/
Old Nov 23, 2021 | 03:06 AM
wilcar's Avatar
wilcar
one range colder.
Good to know! Thanks. Wilcar
Old Nov 23, 2021 | 09:16 PM
garykuter's Avatar
garykuter
When I looked up the ngk ur45, it says it doesn't fit my 77 vette.
Old Nov 23, 2021 | 09:26 PM
garykuter's Avatar
garykuter
What do you think about the NGK 7401 ? expensive plug though. I'm just looking for the best plug for my mildly stock 350 block. Like i said before its a 350 L82 block with the stock heads, headers, and edelbrock manifold with a 600 cfm. The only thing I have done is change the gears from 370 to 390. Thanks for your help.
Old Nov 23, 2021 | 09:27 PM
REELAV8R's Avatar
REELAV8R
its wrong. Just gap it correctly.
I see that you can just buy the ur4 or ur5 and the only difference is the gap. But whichever is available, or cheaper. You got to check the gap no matter which you buy in any case.
Old Nov 23, 2021 | 09:33 PM
garykuter's Avatar
garykuter
says the ur4 fits. All the web sites say the same with the ngk ur45
To spark plugs
Old Nov 23, 2021 | 09:34 PM
REELAV8R's Avatar
REELAV8R
not worth the money IMO. Standard plugs go 30,000 miles. How many years is that in your corvette?
Old Nov 23, 2021 | 09:45 PM
garykuter's Avatar
garykuter
okay. What do you mean years?
Old Nov 23, 2021 | 09:46 PM
garykuter's Avatar
garykuter
Yeah, I always check the gap. Your right.
