New Member
Old Nov 23, 2021 | 11:14 AM
Purban's Avatar
Purban
1st Gear
Default New Member
Hi - I purchased a 1975 white Corvette coupe in 1980, it had 5K miles, it now has 50K miles. I restored the interior and replaced the rear bumper in 1994.
It has been sitting covered in my garage since 1997. I am trying to get it running again, I replaced the battery and will replace all tires if I can get it to run.
I drained as much gas from the tank as I could (color was yellow/orange about 4 gallons) and added about 5 gallons on new gas (clear w/o any color).
Disconnected fuel line at carburetor and attached drain line to 5-gallon bucket. Cranked engine for 15-20 seconds several times emptied bucket after noting fuel color.
Color went from "dark" yellow/orange to light yellow orange after 3 tries. Small amount of sediment noted after each cranking.
Question: Best way to proceed? Drain fuel tank again and re-fill? Keep cranking?
Old Nov 23, 2021 | 01:41 PM
Moved to C3 Tech.
Old Nov 23, 2021 | 02:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Does the car start?
Old Nov 23, 2021 | 02:29 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Pour a bottle of Lucas Fuel Treatment or similar into the tank....the inside of the carb may be nasty, but we can hope it's not .
Old Nov 23, 2021 | 02:34 PM
Stormin_Normin's Avatar
Stormin_Normin
I would give it a shot of starter fluid into the carb and see if it runs. It might take a bit to get good fuel into the carb.
Old Nov 23, 2021 | 03:08 PM
stevedinino's Avatar
stevedinino
After 25 years of sitting, I’d be more concerned that the old ethanol/gas in the carb has absorbed water and corroded the bowl and passages. And I sure wouldn’t want to pump whatever goo has remained into the engine either.
I’d crack open the carb to take a look before I cranked it.
Old Nov 23, 2021 | 03:25 PM
bluthundr's Avatar
bluthundr
I agree, what kind of carb does it have? I would just go ahead and get a Trick Kit or whatever the equivalent is for a Q-jet, look up some YouTube videos, and give it a refresh.
Old Nov 23, 2021 | 03:35 PM
c3_dk's Avatar
c3_dk
Welcome Purban :-)
Let's see some pictures......
Old Nov 23, 2021 | 04:44 PM
pspicci's Avatar
pspicci
If you decide to try and start it i would splice in a clear plastic fuel filter between the tank and fuel pump and keep any eye on it to see how bad it fills up with any possible sediment and or crud from the tank. once you run it for a while and it looks like it will stay clean you can hook up the original lines. if after a couple of fuel filters they keep filling up with crud you will have to address the possibility of replacing the tank.
Old Nov 23, 2021 | 05:22 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
welcome and good luck
Old Nov 23, 2021 | 05:47 PM
How Are You's Avatar
How Are You
Send your carb to Lars.
Old Nov 23, 2021 | 05:53 PM
OldCarBum's Avatar
OldCarBum
I would, open the fuel cap, shine a flashlight into the tank and see if there is any crud floating around or lying on the bottom of the tank.
Then I would drain the oil, and install a new filter and pour in some good 10W-40.
Pull the radiator cap and add water/coolant that fills the radiator 3/4 full.
Hook up a new battery and crank it over.
If it starts, let it run until the gauge starts to rise while checking for fuel, oil or water leaks.
Let it come up to temperature, shut it down and smile the rest of the day.
Once you know it starts and runs, then you can start replacing all the fluids, checking the brakes, putting it in gear and moving it under its own power.
Replace the tires before you put it on the road.
I'm sure you know the belts will probably squeal and you'll need to replace them and all the hoses soon.
If it was running when you parked it, depending on where and how it was stored, it shouldn't take much to get it running.
Good luck and let us know how it goes.
Old Nov 23, 2021 | 06:41 PM
60 SHARK's Avatar
60 SHARK
Yea, I kind of agree, get it to fire up for a minute. Then go after the rest or the things that need attention,,,, complete fuel system cleaning, oil- filter, coolant drain- flush -rad & engine, carb rebuild kit ( it likely will be leaking from every gasket,, KEEP YOUR FIRE🔥 EXTINGUISHER IN HAND ) , Then brake system flush,
Then, after all that,, driveway test it, then decided in tires,,. It will be fun 😀
Keep us posted with pictures,, we luv em.
Welcome,,,
Old Nov 24, 2021 | 10:48 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The stock fuel filter will catch 99% of the sediment......put a new filter in and fire it. If it runs good it does...if not, then pull the carb and go through it.....chances are the accelerator pump is dried up but you do not know for sure. If you get fuel coming out the top when trying to start it could be the float or the needle. Even if there is crud in the tank....if the sock is in good shape....it will catch that too......if you do not like it...the sender comes out the bottom.....easy to rectify with it out.
I have fired a lot of old cars that have sat over the years and it is a 50/50......mostly depends on how dry the storage was.
Jebby
Old Nov 24, 2021 | 11:08 AM
ctmccloskey's Avatar
ctmccloskey
Welcome to the Corvette Forum Purban!
When you buy a new battery be sure to charge it completely before installing it. I would fill the carburetor thru the vent tubes and then see if the engine will start.
I personally don't use my C3 as often as I should and when I let it sit for a few months I will pull the distributor and prime the oil pump with a Dewalt Cordless Electric drill and the priming tool. I run the drill for 2-3 minutes maintaining over 35 psi pressure so everything is well oiled before turning the engine over. It is not hard when you do it regularly, just line up your Timing tab and ensure that your distributor was pointing at the Number 1 cylinder (pointing to ~ 5:30).
Changing the oil before you start it up might be a good idea as old oil can turn acid. Don't forget to get the extra ZINC either in the oil or in a bottle so you can protect your cam and lifters.
Good Luck and I hope the start-up is non-eventful!
Old Nov 24, 2021 | 12:35 PM
Richard Daugird's Avatar
Richard Daugird
My friend had a motorhome sitting outside in the Gulf Coast heat and humidity for 18 years. We squirted some oil in the cylinders, and with some fresh gas she fired right up. Swapped the engine into his daily driver pickup, and it was still running five years later when he sold it. I bet you'll be fine after following the above advice.
Old Nov 24, 2021 | 03:51 PM
ebbnflow's Avatar
ebbnflow
Replace the fuel Sock aka strainer inside fuel tank.
Replace the fuel Filter which is just inside the carb fuel inlet.
To New Member
Old Nov 24, 2021 | 04:20 PM
augiedoggy's Avatar
augiedoggy
Was there even ethanol in the old gas when he parked it in 1994? I dont believe so.
Old Nov 24, 2021 | 04:28 PM
ebbnflow's Avatar
ebbnflow
Yes. It was introduced in the forties and by late seventies was widely available as Gasohol.
https://www.sciencedirect.com/topics...iences/gasohol
Old Nov 24, 2021 | 04:40 PM
augiedoggy's Avatar
augiedoggy
Interesting... a google search says it was avaliable as early as the 20s.
It wasnt a thing were I live, at least not widely sold or used in the quantities were it damaged rubber and carbs until the energy policy act of 2005 set a minimum for such adjuncts thats also when the pumps started designating whether it was gasoline or the mix.
