C3 Half Shaft
Old Nov 25, 2021 | 12:09 PM
seanshine's Avatar
seanshine
5th Gear
Default C3 Half Shaft
Quick question. Does the inner flange on the rear half shaft have French locking tabs like the outer flange. There were none when I took it apart. but it seems like its not too safe with only 16 pounds torque. Thanks
Old Nov 25, 2021 | 12:15 PM
stevedinino's Avatar
stevedinino
They do not. Couldn’t hurt to add them I guess. I just used loctite.
Old Nov 25, 2021 | 01:12 PM
seanshine's Avatar
seanshine
5th Gear
Loctite is is. Thanks
Old Nov 25, 2021 | 02:17 PM
69L88's Avatar
69L88
Loctite Blue if you want to take it apart down the road. If you use Red, you’ll have a much tougher time of it.
Old Nov 25, 2021 | 02:25 PM
kossuth's Avatar
kossuth
Everything I work on gets a smear of loctite blue (except wheel lugs etc) unless it calls for red.
Old Nov 25, 2021 | 03:23 PM
seanshine's Avatar
seanshine
5th Gear
16 pound torque just doesn't seem right to me. The outer flange torques to 65 pounds with French lock tabs. Is there something I'm not seeing here?
Old Nov 25, 2021 | 07:48 PM
69L88's Avatar
69L88
No, you are seeing it right. Torque them to 15-20 with the Blue Loctite. If you want some additional comfort, paint a witness mark on them and check them down the road.
To C3 Half Shaft
