Strut rod size C3
Old Nov 28, 2021 | 11:19 AM
fake's Avatar
fake
Default Strut rod size C3
Can you run any size strut rod in a 1975-1977 . What are the differences on a FE7 suspension verses a base?
Old Nov 28, 2021 | 12:26 PM
interpon's Avatar
interpon
Pretty sure 75 was the start of the larger strut end size..
no difference in fe7 or gymkhana i can think of compared to base
Old Nov 28, 2021 | 01:28 PM
PJO's Avatar
PJO
Veteran: Marine Corps
1974 and later were 1 3/4" 1973 and earlier were 1 1/2" diameter.
Old Nov 28, 2021 | 08:25 PM
kodpkd's Avatar
kodpkd
I rebuilt my strut rods on my 68. Little did I know, they were the larger diameter ends. I purchased the larger bushings. I think the inside diameter is the same. I had to use a propane torch to burn the old bushings out. Cleaned and painted to rods, installed the new bushings,,,,, good as new. Oh,,, and you can even adjust the rear suspension camber.
Old Nov 29, 2021 | 08:36 AM
panther-19's Avatar
panther-19
FE7 in my 82 had front and rear stabilizers as well as aluminum strut rods with multi-leaf steel rear spring (9 leaf). My non-FE7 1975 coupe had no rear stabilizer, steel strut rods and multi-leaf rear spring (9 leaf also).
To Strut rod size C3
