1975 c3 exaust
Old Nov 29, 2021 | 05:55 PM
Bob’s1975C3's Avatar
Bob’s1975C3
5th Gear
Default 1975 c3 exaust
I’m looking for some guidance on a nice sounding exhaust system for a 1975 C3. My car is very original and I’d like to keep it as original/stock as possible. I’d like to get a better sound than just the stock sound. Would something like “glass packs” be recommended? Also, is it a bad thing to get rid of the catalytic converter when trying to maintain originality?
Old Nov 29, 2021 | 06:33 PM
Aquarian's Avatar
Aquarian
Hi Bob...would depend if you wanted to keep it all original for NCRS judging. I used to go to Midas for the mufflers on my 73 back in the day. The gold mufflers looked pretty cool under thee car. Other wise check out Borla, Corsa or Magnaflow, lot of choices in the after market.. 75 has one cat and then splits off to duel from there, if you are considering removing the cat think about replacing it with a real duel exhaust system. All depends on your end game.
Old Nov 29, 2021 | 06:41 PM
BLUE1972's Avatar
BLUE1972
Just be careful with your choice, some "muffler" systems can make the inside of the car unbearable. The interior resonance can cause a very unpleasant ride.
If you do a lot of cruising, stock / almost stock is better, ESP if you have a female with you.
There are numerous threads on the mufflers, I would suggest you read them. Also if there is a local corvette club - ask fo a ride and talk to members to get the opinions.
Old Nov 29, 2021 | 08:37 PM
Bob’s1975C3
5th Gear
Thank you both. Good advise. I’ll look for the threads.👍
Old Nov 29, 2021 | 09:32 PM
Luckyatlast's Avatar
Luckyatlast
I just finished putting a Magnaflow system on my ‘69. Really like the sound. Not loud, but a nice tone. Haven’t done much driving yet, but no noticeable resonance in the car. They recommended professional installation which I ignored and now I understand why they would recommend it. I would too now, not because it’s difficult to do, but rather because the instructions are minimal and there are some things that need massaging relative to getting sufficient ground clearance. I’m impressed with the quality of the system.
Old Nov 30, 2021 | 12:15 AM
Gearhead74's Avatar
Gearhead74
I have a '74 so my exhaust is a full dual without catalytic converters. I always considered the best sounding mufflers to be the stock units on my '63 but even years ago I was unable to find anything that even came close to that sound. I never liked the MagnaFlows and similar competitors so for some time I just ran generic Midas mufflers. Some time ago I discovered someone had reverse engineered the original GM off-road N11 muffler. As I recall, at that time they were sold exclusively through Corvette Central. That may no longer be true, I don;t know. In any event, I've been happy with them. I should add however that I upgraded the exhaust to 2.5 inch diameter coming out of 2.5 diameter rams horn exhaust so I've essentially replicated on my '74 what I had previously known on a C2. I also insulated the entire interior under the carpet both to minimize noise and especially heat. Without the insulation these mufflers may be a bit loud for you. Also, I don't know how well they will fit unless you revert to a full dual exhaust.
Old Nov 30, 2021 | 11:05 AM
SEVNT6's Avatar
SEVNT6
Only if you're going NCRS. Otherwise ditch it!
'75 was GM's 1st cat and it has the same flow rate as a box of frozen peas.
I went with the Corvette Central Magnaflow dual system with 2 1/2" pipes years ago.
No more Y-pipes and the sound is not much louder than stock.
Installation would of been a lot easier with a rack, but I was still able to get-er-done......
Old Nov 30, 2021 | 11:31 AM
Roy W.'s Avatar
Roy W.
Disabled by request 8 JUN 2025
Dump the cat and go with a 2 1/2 inch system and stock mufflers.(Walkers @ Rock Auto)
Old Dec 1, 2021 | 10:34 AM
Z0Tex's Avatar
Z0Tex
I went with the same system on my 1980 just a few days ago. Here is a clip and some pictures...
Attachment 48335308
Attachment 48335309
Attachment 48335310
Attachment 48335311
Installed, but position not finalized.
Attachment 48335312
Old Dec 1, 2021 | 11:03 AM
Bob’s1975C3
5th Gear
Great ideas. Before this post I had no clue. I think I’m going to dump the cat and go with a close to stock dual system with mild/mod sound. Many thanks!
Old Dec 1, 2021 | 01:35 PM
pmr2000's Avatar
pmr2000
Went true duals and Magnaflows on my stock 1975 L48. Sound good when on the gas, pretty quiet cruising, no drone. Similar noise levels to "touring" type mufflers, quieter than Flowmasters.
Old Dec 1, 2021 | 05:13 PM
Richard Daugird's Avatar
Richard Daugird
I'd go with headers as well, frees up power and better gas mileage.
Old Dec 1, 2021 | 09:46 PM
randallsteel's Avatar
randallsteel
My opinion, electric cutouts are a great thing to add! You can have a quieter cruising style muffler, avoiding any loud drone, but push a button and have very loud open header noise whenever you want it.
I have a 2.5 inch dual setup, H-pipe with two dynomax single chamber mufflers and electric cutouts right after the headers.
Old Dec 2, 2021 | 09:03 AM
jelliott25's Avatar
jelliott25
I'm looking at getting new mufflers as well. My 75 has headers and a full dual exhaust with flowmasters (no cats) and it's really unbearable in the car. At certain RPM the whole rear deck area buzzes and vibrates like crazy. I'm wondering if quieter mufflers will alleviate some of that or if I've got something loose back in there. I've getting tires done on Saturday and may just stop by Midas after that to see what they can do for me without me spending an arm and a leg.
I must be getting old when I want my car to be quieter instead of louder.
To 1975 c3 exaust
