Blower motor question
Old Dec 8, 2021 | 05:43 PM
dmarcoui's Avatar
dmarcoui
3rd Gear
Default Blower motor question
I’m new to the corvette owner world. I’ve always loved them and recently bought a 1980 corvette which needs a small amount of attention. Question is my blower switch for air and heat does nothing. Thoughts on steps to solve my problem?
Old Dec 8, 2021 | 06:13 PM
Vette_DD's Avatar
Vette_DD
Welcome to the forum.
Do you have a copy of the owner's manual so you can look up where the fuse for that circuit is?
Old Dec 8, 2021 | 06:16 PM
dmarcoui's Avatar
dmarcoui
3rd Gear
Unfortunately I do not. Tried You Tube for location without luck.
Old Dec 8, 2021 | 06:39 PM
Moved to C3 Tech.
Old Dec 8, 2021 | 07:07 PM
interpon's Avatar
interpon
Fuse? Ground on blower? Try power and ground directly to blower. There is a relay for high speed and resistor for lower sppeds. Work backwords to switch.
here are some diagrams if helpful…its a 79 but probably close.
post some pics of your ride!! And blower area..
Old Dec 9, 2021 | 08:43 AM
bmotojoe's Avatar
bmotojoe
FYI...
The drawing above page 8A-38 is a NON A/C equipped car.
Notice, there is no High Speed Blower Relay in the circuit.
To OP, with car OFF and the fan speed switch in the LO position and the upper slider control in the OFF position do you hear your blower motor running with ignition switch in the ON position?
The intent was to keep air circulating in the cabin even if the heater controls are in the OFF position.
Old Dec 11, 2021 | 03:00 PM
Dodosmike's Avatar
Dodosmike
Originally Posted by bmotojoe
FYI...
this.
To expand on above, there is no "fan off" position. Was designed to continually run on low speed.
i pulled the connection on top of the blower motor to shut it aff decade ago. No fan, less heat in the cabin. Heat soak through the floor was enough for me.
To Blower motor question
