Intake Manifold Install Question.
Old Jan 8, 2022 | 03:30 AM
  #41
derekderek's Avatar
derekderek
you can seal a bathtub like that. bathtubs don't generate vacuum and blowby. fine drive it. don't drive it too far. now get the correct manifold gasket. and stop using the rubber china wall gaskets.
Old Jan 8, 2022 | 08:41 AM
  #42
Cavu2u's Avatar
Cavu2u
you can seal a bathtub like that. .......
That's about what it reminds me of.
Have to install the Ignition Shielding after checking the timing once more, then the Air Cleaner.
I imagine no high RPMs for a while during Break-In. When do you re-torque the bolts on aluminum Cylinder Heads?
Thanks Derek.
Steve
Old Jan 8, 2022 | 08:58 AM
  #43
l8279vette's Avatar
l8279vette
The rubber seals work on cast iron intakes .GM uses silicone on all aluminum intake manifolds read a shop manual 79 corvette .
Old Jan 8, 2022 | 06:04 PM
  #44
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
If torqued properly in the first place with quality gaskets.
You shouldn't need to re-torque head bolts.
Old Jan 8, 2022 | 06:05 PM
  #45
4-vettes's Avatar
4-vettes
And, ah, I'd pull that intake back off and do that properly.
Old Jan 8, 2022 | 06:37 PM
  #46
Cavu2u's Avatar
Cavu2u
I believe you would too, judging by your high standards.
If you knew what I've gone thru most of 2021 and so far in 2022 with this car, you might understand my urgency in driving it now. Someday I will: it's the proper thing to do.
Thanks.
Steve
Old Jan 8, 2022 | 06:47 PM
  #47
Mooser's Avatar
Mooser
Originally Posted by 60 SHARK
Quote:
Originally Posted by Mooser View Post
Just needs one to not seal to make it aggravating enough to not bother anymore...
M
EXACTLY,, 💯%,,,,
We've all been there
M
Old Jan 8, 2022 | 08:21 PM
  #48
bluthundr's Avatar
bluthundr
Originally Posted by Cavu2u
Old Jan 19, 2022 | 05:54 PM
  #49
ebbnflow's Avatar
ebbnflow
I know; late to the party.
I would not have used those thick 0.120" intake gaskets unless deck milling absolutely Dictated it. Perhaps only elongating intake's bolt holes.
Nor would I have used the rubber china wall seals.
Nor would I have used right stuff on intake ports as well as china walls; it may be a bear next time you R&R it.
