1979 Cat delete?
Old Jan 3, 2022 | 05:14 AM
Budryzer's Avatar
Budryzer
Default 1979 Cat delete?
Greetings,
Is anyone aware of a bolt in cat delete pipe for my 1979 that can be purchased?
Old Jan 3, 2022 | 05:36 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Don't waste your time. Seriously, any exhaust shop can make up a "test" pipe. But putting on a true dual exhaust is good for 50 - 80 H.P.
That 2 into 1 back into 2 system just plane sucks!
Old Jan 3, 2022 | 08:47 AM
interpon's Avatar
interpon
Originally Posted by Budryzer
Greetings,
i was where you are..here..and minewas working fine !
https://www.corvetteforum.com/forums...79-4speed.html
agree, do not waste yourtime for 2 reasons
at least when i was looking..all unobtainium ebay etc..
you will be 1/4 to 1/3 into the cost of duals…
your 79 still has holes for duals..
While at it remove the exhaust diverter on passenger side when adding duals
good luck
Old Jan 3, 2022 | 11:03 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Don't know about the rest of the country but there's a HEAVY fine for exhaust shops here if FL that are found performing any work involving eliminating a car's converter.
Old Jan 3, 2022 | 11:42 AM
wilcar's Avatar
wilcar
Very true! When I lived in Tampa years ago Hillsborough County had smog regs so somebody always knew somebody else that could take care of you if you wanted a "dirty" exhaust up grade. Probably much harder to find today but they are around!
Old Jan 3, 2022 | 12:53 PM
Tranz Zam's Avatar
Tranz Zam
Take that heavy pos off and throw it in the woods!
The cats on these era GM cars are mostly all the same shape. I had a test pipe off a 78 Vette fit a 77 Trans Am. I'm sure there's a company or two that are still making them.
I would suggest going the dual route and getting rid of that horribly restrictive Y-pipe though. I couldn't believe how small and poorly routed the original was on my 78 I'm building.
Old Jan 3, 2022 | 01:01 PM
derekderek's Avatar
derekderek
i wouldn't ask a shop to do a job like that. just buy a sawzall...
Old Jan 3, 2022 | 01:23 PM
bluthundr's Avatar
bluthundr
Alternatively, take the cat off and mash all the guts with a crow bar, dump it all out, and reinstall. You just turned your old cat into a resonator for free and it will still pass visual inspection.
Old Jan 3, 2022 | 06:16 PM
interpon's Avatar
interpon
Removing the cat without cutting is a fantasy…
get duals
Old Jan 3, 2022 | 07:21 PM
Budryzer's Avatar
Budryzer
1979 has a bolt in pipe (for the CAT)..... Its strange, I know.
Old Jan 3, 2022 | 08:15 PM
interpon's Avatar
interpon
oh I know …try to remove those bolts..let alone get a wrench on some..
Old Jan 4, 2022 | 01:21 AM
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
I have a 79.i purchased a dual exhaust system by Pypes SCC10S with x pipe and street pro mufflers and chrome tips. I literally bolted right in. I did it in my garage with nothing more than hand tools. It looks and sounds amazing. As far as the person claiming to gain 50 - 80 HP. I call bs. There is absolutely no way to gain that much Hp from an exhaust system. 5 - 8 HP maybe.
Old Jan 4, 2022 | 02:40 AM
Shark Racer's Avatar
Shark Racer
The 2-1-2 with a single 2.25” pipe is a BIG detriment to performance on these cars. That said, 50-80 is a crazy number, unless someone has a crazy motor with big headers in front of a 2-1-2 2.25” setup.
Realistically, there is probably 10-20 hp to be found on a stock motor, a bit more if you have removed the factory manifolds and replaced with long tube headers.
That said, modern cats are very efficient and even on a high performance motor lose very little power, assuming they are appropriately sized to the engine along with the rest of the exhaust system.
Old Jan 4, 2022 | 06:32 AM
Budryzer's Avatar
Budryzer
Thanks for the info TL79C3 What did you do with the heat riser? Also, is there a clearance issue with the speedometer cable and the driver side pipe?
Old Jan 4, 2022 | 06:36 AM
Budryzer's Avatar
Budryzer
It could have been a typo..... 50-80 + 5.0 - 8.0 hp That more realistic. Not sure what is inside the '79 cat but I am curious.
Old Jan 4, 2022 | 07:12 AM
4-vettes's Avatar
4-vettes
No typo. lose factory exhaust with it's super restrictive Cat. 50 - 80 HP. No ****! Many a thread on this forum over the years on this very topic.
Old Jan 4, 2022 | 07:29 AM
Engage's Avatar
Engage
50-80 hp increase with headers and a cam maybe.
Upgrading to true duals only without changing anything else...... 20-30
To 1979 Cat delete?
Old Jan 4, 2022 | 02:53 PM
TedH's Avatar
TedH
Greetings,
When my local shop installed my dual exhaust, they had to label it as 'cat back'; on the paperwork due to regulations. However, they installed a 2.5" header connected, custom bent, true dual system with h-pipe all the way to my Super Turbo mufflers. That was late 90's. That aluminized system lives today. Worth every penny of the $250 I spent then (on top of the cost to Jet Hot coat my Hedman full length headers).
Old Jan 4, 2022 | 03:33 PM
Fly skids up!'s Avatar
Fly skids up!
Does anyone here have time slips of their before and after exhaust modifications? I don't think the 2-1-2 is all that terrible. To the OP, a new monolithic catalytic converter will probably free up 15-20 HP.
Old Jan 4, 2022 | 04:43 PM
interpon's Avatar
interpon
i posted link pics in my thread earlier.
test if clogged first, i think a vacuum gauge and an IR gun will work..
if clogged maybe 40 HP.. if not my WAG is cat pipe replacement 10-15 hp, go to duals 2.5 inch no headers..15-35 hp, torque?
the original is a pass through bed design with beads..mine actually was working fine.. but fried the floor
