Muncie won't turn.
Old Jan 9, 2022 | 01:16 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Default Muncie won't turn.
I have a M22 that I have had for 15 years and its stuck I cannot turn the Tail Shaft when in Neutral. I was rebuilt and all the Gears look great and Syncros look to be new. So with the Side cover off and the Forks removed I can shift threw all 4 Gears and Reverse. (nothing turning) But when everything is in neutral, I cannot turn the Tail Shaft. In the AM I will remove the Trans and see what happens when I turn the Input Shaft. This Trans has never been run since rebuilt. The Tail shaft will Giggle a bit telling me that the shafts are not froze up. Something is clicking and fells like the clearance between Gears. Its got to be something stupid wrong right in front of me ???
Old Jan 9, 2022 | 03:48 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Well you already know sitting for 15 years isn't the best thing for it. Could just be a bit stiff? Could be a rusted bearing.
Well, you should know more once it's out.
Old Jan 9, 2022 | 05:09 AM
Budryzer's Avatar
Budryzer
I think it's stuck from sitting as well. It should free up when you have the cover off and screw driver some of the gear teeth to get them started
Old Jan 9, 2022 | 06:48 AM
derekderek's Avatar
derekderek
did you try a strap wrench on the driveshaft? you would not want to put a pipe wrench on it. https://www.harborfreight.com/rubber...xoCqhIQAvD_BwE
Old Jan 9, 2022 | 06:49 AM
4-vettes's Avatar
4-vettes
True enough that with a little force one might get it to turn again. However if there is surface rust/pitting on a bearing.
It won't be long for this world.
Old Jan 9, 2022 | 08:18 AM
interpon's Avatar
interpon
I thought the same thing when i rebuilt mine…the linkage was not in neutral.( with and without shifter installed) triple check…and wear a glove.
Old Jan 9, 2022 | 08:50 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Im thinking its still in reverse when you think its in nuetral. Hard to believe it seized but I guess anything is possible. Got any pics for us?
Old Jan 9, 2022 | 09:16 AM
Dirty Dalton's Avatar
Dirty Dalton
Mine sat for well over 30 years; no problem.
Old Jan 9, 2022 | 10:08 AM
Jeffs82c3's Avatar
Jeffs82c3
Are you sure it’s only in one gear? If it’s in two gears it won’t turn no matter how much force you use.
Old Jan 9, 2022 | 10:11 AM
Gale Banks 80'
I have a 24" Cresent on the Yoke. There is no sign of Rust. I will have it off where I can test the Input shaft here in an hour or two.
Old Jan 9, 2022 | 11:54 AM
GTR1999's Avatar
GTR1999
I would remove the side cover before jumping on it with a 24" wrench. It if's locked up I would make sure reverse is not engaged, if the sliders are in neutral and it doesn't move then you should take it apart. I have seen rebuilt trans, sitting for years outside, with bad bearings.
Old Jan 9, 2022 | 01:01 PM
Gale Banks 80'
Simple Fix. The reverse Paw was not engaged. With the Detent Ball working it " Felt" like it was going in and out of Reverse, but it was not. In other words, it was in Reverse and until I freed it from the Engine, I could not tell why it would not spin. Thanx to all of the above I am moving forward again in more ways than one.
Old Jan 9, 2022 | 01:40 PM
Rescue Rogers
Good job!!
Old Jan 9, 2022 | 11:14 PM
Dirty Dalton
To Muncie won't turn.
