Keeps running
Old Jan 9, 2022 | 11:25 AM
PennyJack's Avatar
PennyJack
Default Keeps running
68 when car is running then I turn it off and take the key out it keeps running. When I hit the dash it shuts off. Any ideas why!!?
Old Jan 9, 2022 | 11:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
First thought is a short in the ignition switch.
Old Jan 9, 2022 | 02:13 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
does sound like a bad ign switch.
Old Jan 9, 2022 | 07:48 PM
PennyJack's Avatar
PennyJack
Actually running smooth idle
Old Jan 10, 2022 | 01:40 PM
PennyJack's Avatar
PennyJack
Car is in storage so I don’t remember why
Old Jan 10, 2022 | 09:56 PM
diehrd's Avatar
diehrd
Run on would not shut off by hitting the dash board . You have an issue with the ignition switch / wires ..
Old Jan 11, 2022 | 04:57 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
And run on, dieseling is obvious. Bad diode in the Alternator or switch not shutting off. Both easy to check.
Step one. temporarily unhook all wires from Alternator. Start car, turn it off. Problem is gone. Bad diode. Problem persists, switch not shutting off.
Old Jan 11, 2022 | 07:35 AM
Budryzer's Avatar
Budryzer
I think this switch is your problem. Its down the column toward the pedals. Anyone done one of these on a corvette? I haven't but they are usually activated by a rod.
https://www.ecklerscorvette.com/1969...MaAkPXEALw_wcB
Old Jan 11, 2022 | 08:20 AM
SteveG75's Avatar
SteveG75
OP’s car is a 1968. Ignition switch is in dash. Completely different.
https://www.ecklerscorvette.com/1968...All%20Products
To Keeps running
