1980 alternator question
Old Jan 13, 2022 | 06:38 PM
scottyp99's Avatar
scottyp99
Default 1980 alternator question
Hi guys!
I have a 1980 Corvette. I put a serpentine belt setup on it years ago, and have always had problems with the power steering pump reservoir, so I'm reverting to the v-belts. I'm looking for an alternator bracket. There is an aluminum bracket, (which I think is the one my car came with, but it has been lost in the shuffle over time) and a cast iron bracket. The cast iron bracket can be found, the aluminum bracket is scarce and expensive when you can find one. The cast iron bracket is said to be unusable with the 70 amp alternator, which I think is the alternator I have. Does anybody know why the cast iron bracket can't be used with the 70 amp alternator?
Scotty
Old Jan 13, 2022 | 06:50 PM
stingr69's Avatar
stingr69
Alternator uses the aluminum base and a steel adjuster arm. There is no cast iron alternator bracket on mine.
We do have a cast iron A/C compressor bracket.
Old Jan 13, 2022 | 07:05 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Huh?
is the alt a stock type?
Like said, a steel adjustment arm was used.
Even the main pivoting mount is steel.
Pictures of the setup?
Old Jan 13, 2022 | 08:28 PM
scottyp99's Avatar
scottyp99
I'm talking about the bottom alternator bracket, the part that bolts to the cylinder head. Here are two links that describe the pieces in question:
Iron bracket: C3 Corvette 1972-1982 Cast Iron Alternator Bracket - 350ci | Corvette Mods
Aluminum bracket: Original GM Alternator Bracket for 1980-1982 Corvette -- P/N 14015510 | eBay
Here is the pertinent phrase from the iron bracket description: Note: This mounting bracket fits all 1972-1978 C3 Corvettes with 350 engines and all 1979-1982 (replaces aluminum bracket) C3 Corvettes except those with 70 amp alternators.
Scotty
Old Jan 13, 2022 | 08:30 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Scotty
awh. yes, alumn. junk yards. good luck
Old Jan 13, 2022 | 08:53 PM
scottyp99's Avatar
scottyp99
So.....a junkyard will be able to tell me why the cast iron bracket won't work with a 70 amp alternator? Is that what you're saying? Because that was the question.
Scotty
Old Jan 13, 2022 | 09:14 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
All of those S10, S12 Alternators mount the same. Perhaps just because the 70 amp Alternators came with the alloy bracket they are listing it as not correct.
Old Jan 13, 2022 | 09:16 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
since the alt is standard for most years, the only thing that pops to mind is how the bracket attaches to the engine.
Apparently the cast steel/iron mounts different than the alumn one.
Not seeing it or how your engine is, I guess I would have to trust the alumn that came on 80-82.
if your links have pics, maybe something will stand out when you compare the 2?
There are still just yards that handle vettes C3s.
Not a lot of part though.
If you have the gm number for the alumn, it will help.
Old Jan 13, 2022 | 10:59 PM
scottyp99's Avatar
scottyp99
Well, I'm rolling the dice and buying a cast iron bracket, and I guess we'll find out for ourselves, eh? I have a feeling I can make it work. See ya!
Scotty
Old Jan 14, 2022 | 03:24 AM
4-vettes's Avatar
4-vettes
Pretty sure it'll be fine!
Old Jan 14, 2022 | 08:48 AM
bmotojoe's Avatar
bmotojoe
When I went to a 80 AMP alternator from a 61 AMP (cast iron mount) on my 77 the mounting was the same.
The differences between the 2 are the physical diameter.
Because the 80-82 and some 79 use a larger rotor and stator the housings are larger, from 5.27" on the 37-63 AMP to 5.73" on the 70-85 AMP.
I have the L82 valve covers installed (taller than the tin) so when I want to remove/replace the belt it is quite snug getting it on/off.
I could go 1/2" longer belt length but it's not much of a problem.
Old Jan 14, 2022 | 09:12 AM
diehrd's Avatar
diehrd
Hi guys!
Scotty
I went through this a long time ago . Its the depth of the alt mounting tabs that cause an issue.
Old Jan 14, 2022 | 12:54 PM
TedH's Avatar
TedH
Hi guys!
Scotty
Here is an option from eBay:https://www.ebay.com/itm/11512019995...BoCuPAQAvD_BwE
I am searching a couple other sites.
This is an alternative: https://www.ebay.com/itm/15269373305...8AAOSwPwpeK0oO
Doc rebuild has the aluminum bracket as well as the top steel bracket. You can even get the belt guard attachment for the upper arm and all hardware:
The lower aluminum bracket: https://shop.docrebuild.com/1979-198...015510NOS.aspx
The top steel bracket: https://shop.docrebuild.com/1979-198...M14015511.aspx
On Doc's site, you even can view a diagram of the assembly (handy).
Old Jan 14, 2022 | 03:29 PM
scottyp99's Avatar
scottyp99
I think this is exactly what I was looking for, thanks for the info. I should be able to work with it.
Scotty
Old Jan 14, 2022 | 03:31 PM
scottyp99's Avatar
scottyp99
I'm not sure what you mean by "the depth of the alt mounting tabs"
Scotty
Old Jan 14, 2022 | 03:32 PM
scottyp99's Avatar
scottyp99
Excellent info, thanks man.
Scotty
Old Jan 14, 2022 | 05:57 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
I think I may have a NOS 80-82 aluminum bracket in my storage unit but would have to check to be sure. On a different note, I am running a 140 amp alternator in place of the stock 70 amp. I did have to get a different length belt though which wasn't surprising.
To 1980 alternator question
Old Jan 14, 2022 | 08:27 PM
diehrd's Avatar
diehrd
Scotty
The Alt attachment end is not long enough with the iron bracket for 79 to 82 models .. And you will end up with valve cover interference.
Old Jan 15, 2022 | 12:15 AM
4-vettes's Avatar
4-vettes
I also run a 140 amp Alternator as I have some non standard electrical loads. I still have the iron bracket that came with the car. It's just bolted to aftermarket heads.
As per the stock belt. That I am certain I am not running.
But what's a V belt cost in the big picture here.
Old Jan 15, 2022 | 11:58 AM
carriljc's Avatar
carriljc
scottyp99
I have a 68 and have used the cast iron bracket with a couple of different heads and it has fit with the original alternator, and 94 amps 12 si, and now with a 140 amp CS-144..... buy it on ebay -- they're a lot cheaper than that ridiculous 200 dollar price.
Here you go: You want to get part number AlternatorBracket 3951337 . It's what I have on my 68 with holes in the head. Below is a link with lots more info and pictures. Pictures of mine are there also. That bracket was used on a lot of short water pump vehicles so don't overpay.
https://www.corvetteforum.com/forums...post1599025318
my setup below with a 68 corvette short water pump: https://www.corvetteforum.com/forums...post1599025910
Hi guys!
Scotty
