Random Info Question
Old Jan 16, 2022 | 05:24 AM
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
Default Random Info Question
I have a 79. Does anyone know what the ZX2 Convenience pkg is?
Old Jan 16, 2022 | 06:16 AM
Budryzer's Avatar
Budryzer
Greetings,
I have it also an would like to know as well. I believe one item is the spare tire light which I have but don't know how its activated.......
Old Jan 16, 2022 | 07:06 AM
Bikespace's Avatar
Bikespace
Pick up a vehicle info kit from here:
https://www.gmheritagecenter.com/gm-...tion-kits.html
Here's what I found in the 79 document.
Old Jan 16, 2022 | 07:27 AM
bmotojoe's Avatar
bmotojoe
The spare tire light is part of the courtesy light circuit.
When either LH or RH or both doors are opened, ALL courtesy lamps are grounded and will/should come on.
Orange wire circuit #140 and White wire circuit #156
This is a rear harness from a 1977 same circuit numbers and wire colors on a 1979.
Notice the socket wire colors are Orange and White, different then the License Plate light that are Brown and Black.
Not 100% sure but turning headlight switch full CCW will also ground the courtesy light circuit...
Last edited by bmotojoe; Jan 16, 2022 at 07:36 AM. Reason: Added Headlight Switch full CCW
Old Jan 16, 2022 | 07:45 AM
bmotojoe's Avatar
bmotojoe
On my 77 I have the old style capacitor style courtesy light delay timer.
When the door(s) close the spare tire light stays on until the delay timer times out...
Old Jan 16, 2022 | 07:54 AM
Budryzer's Avatar
Budryzer
Ahhhhhh Cool. Thanks
Old Jan 16, 2022 | 08:58 AM
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
Spare tire light!??
TL79C3's Avatar
TL79C3
Banned Scam/Spammer
Thank you so much!!
Old Jan 16, 2022 | 09:10 AM
bmotojoe's Avatar
bmotojoe
Originally Posted by TL79C3
Spare tire light!??
look underneath the rear bumper centerline for a light housing exactly like your license plate light housing.
Old Jan 16, 2022 | 09:16 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
Spare tire light!??
Yes, most likely the same kind of lamp housing used for your license plate, is also used underneath the car up under the backside of the rear bumper. Crawl under the rear end of your car with a flashlight....you'll see it, or maybe the bulb still works, could try turning it on👍
Old Jan 16, 2022 | 09:30 AM
BKarol's Avatar
BKarol
To Random Info Question
