c3 gross weight
I tried entering in the search phrase: "1969 Corvette weight" and the second return (corvettestory.com) provided the base weight plus component weights.
Just googling can open up a big can ov worms. Everyone has an opinion. The hard data can get lost in there. The 69's are about as light as the C3 gets. The 68's were about 25-40lbs lighter. The 70 gained about 50lbs over the 69.
This is primary source info direct from GM, without some of the transcription errors seen on Corvette websites (I'm looking at you, VetteFacts.com)
Or search the forum and find where this was asked just a few days ago
https://www.corvetteforum.com/forums...she-weigh.html
Curb weight is what you should be measuring if you want to compare the weight of your car with that of other cars, and that means a full tank.
Scotty
Scotty
You can get into trouble with curb weights, and its slightly more accurate and repeatable with empty weight. Another way you can mess up with curb weights, is tank size. When the tanks got bigger in '78 the curb went up about 40lbs, and very few people take that into consideration. The cars actually got lighter in 78, but the curb weights were up.
These give the base weight plus the additional weight for optional equipment. (Example: for ‘73 the L82 with 4-speed added 42 pounds over the L48 4-speed.)
Tom…
I'll tell you what. Here's your first challenge: I'm gonna get my daily driver/road race 73 coupe UNDER 2800lbs... with ALL OEM parts, save a set ov cheap aftermarket rims and some cheap import seats. And thats with far heavier than stock 295/50's on all 4 corners. So... how?
When it comes to weight reduction, its the smartest guy that wins, and never the richest.
