I wonder.
Old Mar 21, 2022 | 08:57 PM
Little Mouse's Avatar
Little Mouse
Default I wonder.
Called isky cams today was going to ask a question gal on the phone said call a different time could not do that today. I'm just a solid flat tappet person but I wonder if a custom flat tappet cam can be made for the gen 1 sbc but using the newer LS firing order. My understanding is the newer firing order is easier on the crankshaft, bearings and main webs of the cylinder block.
Old Mar 22, 2022 | 04:48 AM
Greg's Avatar
Greg
Just another Corvette guy
Why make it more complicated than it needs to be?
Old Mar 22, 2022 | 06:33 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I just looked up the order. I know most custom cams are cut off of a lrger existing cam. I think to do that would be really custom and be very expensive
Old Mar 22, 2022 | 07:25 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Absolutely unnecessary.
Jebby
Old Mar 22, 2022 | 12:37 PM
Tranz Zam's Avatar
Tranz Zam
It's a 3/2 and 4/7 swap cam. I've seen a few guys running those cams in traditional SBCs, but I haven't personally run one. They're out there, and if you want one you should be able to grab one no problem.
It's the same firing order on Ford 302HOs, 351W, 351C, and I believe the 400. I think they used it on the Mod motors too.
Old Mar 22, 2022 | 01:25 PM
Little Mouse
I think cadillac first used the firing order then as you say several fords used it. Unless it's over priced to do it., will do it based on it is supposed to be easier on torsionial twist on the crank, easier on the bearings.
Old Mar 22, 2022 | 02:59 PM
derekderek's Avatar
derekderek
used in the boat world some to get 5 and 7 not firing together. very few real headers in boats. and they like to run a lot longer at heavy throttle. cars at that rpm and throttle setting are on a speedway oval.
Old Mar 23, 2022 | 04:35 PM
diehrd's Avatar
diehrd
The 5 7 swap is to mitigate heat in that rear corner of the engine .. As you know 18436572 Causes 5 and 7 to fire off one before the other .. Not needed if your not super charging or using nos for high HP by high I mean 700 and up ...
To I wonder.
