High End Miss
Old May 4, 2022 | 08:15 AM
Cobfree's Avatar
Cobfree
Default High End Miss
My 68 is an all stock matching numbers car. The engine was rebuilt several years ago and has run strong. The problem is on hot days and the engine has warmed up, it will start to miss at high RPM's. I notice it while running through the gears. Previously a member suggested to replace the coil which I did and while I thought it did the trick, last week on a hot day it did it again. I also replaced the plugs. I don't drive it a lot and do use a fuel stabilizer for storage. It's a stock 327/300, four speed.
Any thoughts?
Old May 4, 2022 | 10:49 AM
Bandit54's Avatar
Bandit54
I had similar issues my 68 would just die while driving and it ended up being condenser. Changed point and condenser a few days later down again. Replaced with Lectric Limited Electronic Ignition Conversion problem gone.
Old May 4, 2022 | 11:11 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
How about the ignition wires?
Old May 4, 2022 | 02:22 PM
REELAV8R's Avatar
REELAV8R
Is it more of a cutting out sensation or plugs misfiring sensation? It can be very hard to tell sometimes. Keep the throttle buried and see if it completely cuts in and out or not. If it gets worse the longer you hold the throttle down I'd look to fuel.
Pump might be getting weak, sock plugging up (if one was use in 68), float level etc.
If it's misfiring then electrical. Plug gaps? wires? condenser as mentioned.
Old May 4, 2022 | 03:19 PM
kanvasman's Avatar
kanvasman
A long time ago on my c2 i had a similar issue. Chaged and adjusted everything. No luck. Then I swaped out the distributor and the problem went away. It was original to the car so probably about 12 yrs old at the time. I was too young to follow up at the time (slightly bent shaft,worn gears. I really can’t say. I just it went away and never had that problem for the next 10 years as long as I owned it.
Old May 4, 2022 | 08:53 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
could be floating the points. could be a crack in the cap if its just heat related...
Old May 5, 2022 | 08:19 AM
Cobfree's Avatar
Cobfree
Cutting out at around 4K RPMs but only when it is hot outside
Old May 5, 2022 | 08:20 AM
Cobfree's Avatar
Cobfree
I think I will replace the cap
Old May 5, 2022 | 08:21 AM
Cobfree's Avatar
Cobfree
I replaced them and the plugs
Old May 8, 2022 | 03:32 PM
ctmccloskey's Avatar
ctmccloskey
Do you have a spare coil handy? Coils are known to act up when they get hot and as they age. I would swap a coil and see if it continues when your engine and weather both get Hot. On my 1968 BB the coil sits on top of the intake manifold and gets pretty hot and this can help them break down I was told by MSD tech support. I have gone thru 2 MSD coils and the guys at MSD blame it primarily on the heat coming off of the intake. They keep telling me to stop using the round canister style and get one that is Firewall mounted to keep it cooler and less vibration.
Good Luck, I hope you solve it before it's gets too warm outside!
Old May 8, 2022 | 05:09 PM
Cobfree's Avatar
Cobfree
I did replace the coil and it did not work
and will look for the Firewall mounted unit
thanks
Old May 8, 2022 | 05:10 PM
Cobfree's Avatar
Cobfree
i will loom for the firewall mounted version
Old May 8, 2022 | 05:12 PM
Rescue Rogers
do a tune up first
Old May 8, 2022 | 05:15 PM
Cobfree's Avatar
Cobfree
Default Misssing
Any thoughts?
It only does it when I get to 4,000rpms and when it is hot. Tried changing out the coil and it did not work. Will try your suggestion
Old May 9, 2022 | 03:12 PM
sunflower 1972's Avatar
sunflower 1972
I had the same problem bout 4 years ago. Here's how I solved mine.
https://www.corvetteforum.com/forums...ion-coils.html
To High End Miss
