Avoiding reverse reverse flow mufflers
Old Jun 10, 2022 | 02:36 AM
RBrid's Avatar
RBrid
Default Avoiding reverse reverse flow mufflers
Here's my next question. I have reverse flow inserts for my Doug's side pipes. I know, I know, they're restrictive. I think my aging ears will be grateful.
Anyways, I don't know which side is the front (exhaust input) and which is the rear (exhaust output).
So...pictures:
Which side is for the FRONT? Is it A or B ?
Thanks!
Old Jun 10, 2022 | 06:49 AM
sleepchamber's Avatar
sleepchamber
I guess you could try it both ways. Looks like using side a as the input would break up the exhaust flow more.
Old Jun 10, 2022 | 07:25 AM
SFOcean's Avatar
SFOcean
A is the inlet and B is the outlet.
And they are extremely restrictive however a fair bit quieter than new stock mufflers.
Old Jun 11, 2022 | 02:27 PM
MelWff's Avatar
MelWff
So...pictures:
Thanks!
the inlet is A so that the exhaust gas can enter the small perforations and break up the sound. If you use B the exhaust just flows past the perforations.
Old Jun 11, 2022 | 02:43 PM
MelWff's Avatar
MelWff
Note how on this reverse flow/quiet no perforations and hole is offset. You are sure you have the correct insert?
Old Jun 11, 2022 | 04:19 PM
RBrid's Avatar
RBrid
Default Pick a side
Oh dang, I'm just coming back from the garage after spending an hour installing one of the mufflers using B as the inlet. Now I have two contradicting answers!
If I had to pick who is right, SFOcean or MelWff, I'm tempted to pick SFOcean for two reasons:
#1. I'm guessing it's called a reverse flow muffler because the gases have to travel backwards into the little holes.
#2. I can only slip the mufflers into the 4" pipe one way, and that is using A as the outlet. I would have to grind the perimeter of the B side to be able to slip it in all the way.
Am I right??
The shipping box says 21002HKR which does point to reverse flow versions: Hooker Headers 21002HKR Hooker Super Competition Sidetube Slip-in Mufflers | Summit Racing
Anyways, thanks much for all the input everyone!
Old Jun 11, 2022 | 04:36 PM
SFOcean's Avatar
SFOcean
I checked mine on the car, they are installed with the punched holes facing forwards just as they would be in a standard glass pack installation.
Here are photos of the Hooker 21002HKR cut apart.
Old Jun 11, 2022 | 04:47 PM
RBrid's Avatar
RBrid
So SFOcean, to be clear, you're saying the opposite of your original post? Thanks!
Old Jun 11, 2022 | 04:51 PM
RBrid's Avatar
RBrid
Oh, I see that you edited your original answer and reversed it (no pun intended ). So at this point I think we have two consistent answers. And in order to make that work I would have to grind the perimeters of the B sides so they can slip in.
Old Jun 11, 2022 | 05:02 PM
MelWff's Avatar
MelWff
I also see he reversed his original post to match mine. I'm using Classic Chambered inserts and they were clearly marked by the manufacturer as to inlet and outlet.
Old Jun 11, 2022 | 05:20 PM
SFOcean's Avatar
SFOcean
Yes - and as for the restriction, my large cid BBC loses 150+ rear wheel HP on the dyno when all of the exhaust is flowing through the reverse flow mufflers. The exhaust is relatively quiet in this mode though.
Old Jun 13, 2022 | 05:22 PM
Chambered's Avatar
Chambered
Hate to admit it, but I wouldn't run those inserts on a 289 2bbl Mustang. At the inlet, talk about hitting a WALL before exhaust is forced into the little core tube. Terrible design. But quiet!
Old Jun 14, 2022 | 12:21 AM
RBrid's Avatar
RBrid
Default All done
Wow, that is more loss than I expected!
I am starting with the reverse flow mufflers and at some point later will probably experiment with louder/less restrictive ones. Those mufflers are pretty cheap compared to the thousands of $ I am putting into the car so to me it's worth trying out several options.
By the way I could not find a single video on the web with reverse flow side pipes - no sampling of the sound out there!
For future readers who may face my same original question: is "A" or "B" the inlet?
I did not undo the work I had done, I did not grind down the perimeter on the "B" side to make it fit as an outlet. Instead I mounted the second muffler just like I did with the first - that is with "B" as the inlet.
The reasons:
- I asked around on another car forum and was told B is the inlet.
- On Hooker Headers 21002HKR Hooker Super Competition Sidetube Slip-in Mufflers | Summit Racing, one customer asked "Are these mufflers directional?". And the given answer was: "They can only go in the tube one way. One end bigger than the other…"
So I assume that what I did is correct.
Picture time:
Old Jun 14, 2022 | 08:42 AM
augiedoggy's Avatar
augiedoggy
I have a set of 2.25 sweet thunder inserts with about 1400 miles on them im trying to get rid of... went to classic chambered myself and there is less drone. on both sets the inlet is tapered both inside and outside for less restrictive flow.
Old Jun 14, 2022 | 11:22 AM
Chambered's Avatar
Chambered
Thank you.
Old Jun 14, 2022 | 11:54 AM
MelWff's Avatar
MelWff
I also went to Classic Chambered, 33" Resonator, from the reverse flow and really woke up the engine. They were clearly labeled as far as flow direction and the openings of the perforations face the inlet of the side pipe.
Old Jun 14, 2022 | 12:26 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
just curious for the future, were the Sweet Thunders too loud?
To Avoiding reverse reverse flow mufflers
Old Jun 14, 2022 | 03:21 PM
augiedoggy's Avatar
augiedoggy
Not "louder" per say just had a different pitch to the sound, on the highway at 3,000 plus rpm they had a drone to them which became annoying to me. To be fair every installations a bit different since the material the pipes are made of, cubic inches and the compression ratio all play into the sound a bit. I tried wrapping then in fiberglass harley sound deadener and such with no real effect.
Old Jun 15, 2022 | 08:47 PM
Eagle72's Avatar
Eagle72
7th Gear
SFOcean will be hearing from my copyright lawyer...
To anyone interested, I ultimately ended up with sweet thunder 2.5" inserts.
Old Jun 16, 2022 | 12:06 AM
SFOcean's Avatar
SFOcean
Originally Posted by Eagle72
SFOcean will be hearing from my copyright lawyer....
LOL, your photos really helped me figure out the flow path, thanks again.
