What valves should I get?
Old Jun 26, 2022 | 06:23 PM
Preston.Corvette's Avatar
Preston.Corvette
Default What valves should I get?
Basically the title. Ive never done something like this, but I think one of my exhaust valves has cracked and is causing my car to idle super rough. I want to replace them, but have no idea what to get? Any pointers or tips also welcome!
Old Jun 26, 2022 | 07:44 PM
augiedoggy's Avatar
augiedoggy
I would wait till you actually pull the head and verify whats wrong.
Old Jun 26, 2022 | 08:35 PM
scottyp99's Avatar
scottyp99
Good advice. You can get Melling valves from Rock Auto for cheaper than anywhere else.
Scotty
Old Jun 26, 2022 | 08:46 PM
lars's Avatar
lars
Have you done a leakdown test to verify that..? I've never seen a "cracked" exhaust valve... If you're just going to repair and replace a single valve, you can simply use a stock replacement Sealed Power valve available from any NAPA store for about $10. The gasket set will cost you more than the valve, but you better verify your problem before you go tearing into it...
Lars
Old Jun 26, 2022 | 09:52 PM
HeadsU.P.'s Avatar
HeadsU.P.
Verify that the valve is allowed to close fully and not hanging up.
Did someone just set the valve-lash?
With the valve cover off, jog the key until the adjacent valve is opening. Now grab the suspect rocker.
Should have "some" play in it.
To What valves should I get?
