Mono leaf recommendations request
Old Oct 8, 2022 | 01:31 PM
Hud1086's Avatar
Hud1086
I know this is a fairly old post, but has anyone had any experience with the Corvette America composite spring? They have a 315 that should match well with my ‘69 small block.
Only reason I consider them is because I also need to replace my rear strut rods as well and I can get the spring, bilstein shocks and strut rods at one place and with 15% off sale currently…. But don’t want to get it if someone has experience with it being trash…
Old Oct 8, 2022 | 01:36 PM
Bikespace's Avatar
Bikespace
Do they resell a VanSteel low-arch spring at a discount? If not, don't do it.
Old Oct 8, 2022 | 01:40 PM
Hud1086's Avatar
Hud1086
I’m not sure… this is the one they sell: https://www.topflightautomotive.com/...ll-block-only/
Old Oct 8, 2022 | 01:49 PM
Bikespace's Avatar
Bikespace
That's the Hyperco spring. Lots of threads on why not to use it. VanSteel may have a lead time, but it is likely worth it.
Old Oct 8, 2022 | 05:47 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Here is my suspension setup spreadsheet Bikespace mentioned.
The stock spring is very soft, and since you have a strong engine, you could easily be squatting the rear enough to hit the bump stops, especially coming out of a turn. That could be the "unsettled" feel you are feeling. I did suspension engineering on my Pro-Solo car for 27 years and like you I also decided on the 474# fronts and 330# mono rear for my retirement ride, with it's 500 HP BB. Unlike other BB guys I am setting mine up to handle very well, up to street / auto-cross levels. And yes adjustable shocks definately will let you dial-in your ride/handling compromise. Which with a non adjustable shock is always a hit-or-miss proposition. I have QA-1 adjustables. But many here say the Bilstein combo you have works well with a monospring rear.
Old Oct 9, 2022 | 10:35 AM
sci85's Avatar
sci85
Thanks for posting. Cool spreadsheet. I talked to VanSteel and they recommend the 360lb spring. Just waiting now for them to get enough orders. I think he said they wait until they have at least 6 before they make a batch. I’ll post the results once I finally get her in.
Old Oct 13, 2022 | 10:18 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Mind sharing info on your wheels & tires? Love 'em.
Old Oct 14, 2022 | 08:45 AM
sci85's Avatar
sci85
Sure. I’m running Vision wheels, 18x8.5”, 4.5” backspacing. Tires are Front 235/50r18, Rear 275/40r18.
Old Oct 14, 2022 | 09:53 AM
n2h2o2's Avatar
n2h2o2
Old thread,but anyone with a squatting problem because of added power need adjustable drag shocks...
The idea is you want a shock that requires more force on compression. This will prevent squat BUT you will feel every bump in the road. The trick is to "Dial In" the compromise between performance and comfort...
Here is an excerpt from Summit Racing on some drag shocks they sell.
"The ratios for the rear shocks are 70/30, 60/40, and 50/50. These numbers represent the percentage of force required to extend (first number) and compress (second number) the shock. By changing the settings on the front and rear shocks, you can dial-in the car to raise the front on initial launch for weight transfer, and then settle smoothly for a final charge to the finish line."
Old Oct 8, 2024 | 04:39 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
I recommend Van Steel!
Old Oct 8, 2024 | 05:20 PM
augiedoggy's Avatar
augiedoggy
Since someone else resurrected this old thread ill chime in that im running the dual adjustable shocks along with the composite rear spring in my car for this reason... I am also running the same vision wheels (black version) as SCI85 and have been for about 8 years now with no issues.. I do run 1/2" spacers in the rear though I dont need to.
Van steel is the only decent spring without too much arch I know of left from the research ive done since they use the old VB&P molds.... I found a used VB&P spring on ebay im running now with the van steel Delrin rear crossmember solid lowering mounts.
Old Oct 9, 2024 | 07:46 AM
litevette's Avatar
litevette
Great thread with great info!
