Conditions for initial start?
Old Aug 24, 2022 | 08:19 PM
  #41
Mr D.'s Avatar
Mr D.
Originally Posted by Muuhaha
Well here's something. I put my fluke on the coil + and ground and I had full 12v. When I was cranking, the power went down to 7 or 9v... I forget which. It was my assumption that the R terminal sent 12v ONLY when cranking and was dead the rest of the time, no?
Ignition SW Off - 0V at the + side of the coil
Ignition SW On - 9V at the + side of the coil
Ignition SW Crank - 12V at the + side of the coil
The above depends on the charge condition of the battery, 9V at the coil should still start the engine. I assume you are verifying the coil wire is firing using the timing light??? That would rule out the coil and points so why is the coil discharge not making it through the Dist cap onto the rotor and then onto the spark plug towers.
Old Aug 24, 2022 | 09:25 PM
  #42
Muuhaha's Avatar
Muuhaha
Yeah I remember reading that above which is why I mentioned it... Doesn't make sense. I'll separate the 2 wires tomorrow. It's possible the resistor wire isn't the resistor wire, or the r terminal is doing something crazy. I'll figure it out.
And yes, using the timing light on the coil wire is how I figured it was good. I also took off the cap and cranked and saw the points sparking. I kinda ruled it down to the rotor/cap, hence ordering a replacement to make sure. If that doesn't fix it I'll be fresh out of ideas. I tripped checked all my work (go figure, I'm an electronics engineer haha) so this issue is kind of stumping me beyond a failed component at this point!
Old Aug 26, 2022 | 07:57 PM
  #43
Muuhaha's Avatar
Muuhaha
Default Update
Ok so an update...
I got an AC Delco cap and rotor... Both were significantly different than the one that was on the car. I also got my spark tester light to go in-between the plug/wires.
Put in the new cap and rotor, put the tester between #1 and #2 plugs and got some lights going on during cranking. Drained out about 2gal of old fuel and put in 5gal of 93.
I put some gas into the carb to fill the bowls and cranked it. It turned over, we had some combustion (and smoke!) And the wife told me the fuel meter moved, so we're good on that angle. I think i ended up killing the battery though, so it's on the charger. If anything I'm probably going to get a red top just to have everything fresh.
So now that we're assuming everything is in place, is there anything else I should set? I set the throttle on the carb and the idle screws on the side, and the float screws on the top (going off memory, 1 turn for the throttle, 1.5 turns on the idle screws, float screws were pretty much good). Should the distributor be angled a certain way or anything crazy like that?
I think tomorrow might be the day! Appreciate your help so far fellas!
Old Aug 26, 2022 | 08:58 PM
  #44
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Congrats!!!
You should make sure you are timed correctly meaning zero on the balancer is in fact pointing at #1 and not 180 degrees out....it happens all the time
Old Aug 27, 2022 | 08:16 AM
  #45
Muuhaha's Avatar
Muuhaha
Congrats!!!
Gotcha -- I used a TDC stopper in the spark plug hole to find tdc, marked it on my balancer, then spun the engine the opposite way, marked it again, and put true TDC at half way between the 2 marks. It made true TDC 5* on my balancer. Im going to regap all my plugs and then verify im on TDC compression, and that the rotor is pointed at #1 and give it a go!
If it is 180 out Im assuming I just rotate the engine 1 full revolution and put the distributor back in?
Old Aug 27, 2022 | 10:59 AM
  #46
Mr D.'s Avatar
Mr D.
With TDC set on your balancer / timing mark (piston stop method you did) just make sure the rotor is pointing at the #1 spark plug tower. If pointing at the #6 spark plug tower than you are 180 out and will need to remove the Dist and rotate rotor to the #1 tower, don't turn the engine over during this step. You want the #1 piston at TDC when you install the Dist.
Old Aug 27, 2022 | 03:53 PM
  #47
Rescue Rogers
that is correct
Old Aug 28, 2022 | 03:14 PM
  #48
Muuhaha's Avatar
Muuhaha
TDC was correct, after cranking and cranking the Mrs noticed some seepage around the carb. I took a look and it definitely looked like some gas was leaking out. So instead of chancing anything I ordered a new Holley 4160 (0-80508S) should be here Wednesday 😮‍💨. Thought about rebuilding what I already had but everything else is new so may as well keep it symmetrical!
Old Aug 30, 2022 | 10:38 PM
  #49
Muuhaha's Avatar
Muuhaha
Carb is on, and we're further than before. Seems like now, if I hold the key in the start position, it'll stay running... if I let go, the car dies. I can rotate the distributor a bit and it helps (atleast sounds better) but same thing.
I now have fuel pressure holding on my gauge too! The Mrs is still on standby with the fire extinguisher 😅 just in case.
Any ideas?
Old Aug 31, 2022 | 06:18 AM
  #50
Rescue Rogers
Sounds like the power to the coil. You should have either 2 sources, one from the starter when its cranking, and then another when its in run. There should ne a white and a yellow wire going to the coil. I dont know If the wire for "run" is fused
Old Aug 31, 2022 | 07:15 AM
  #51
Muuhaha's Avatar
Muuhaha
Yeah, I know for a fact the run wire is there, I ohmed it out. The resistor wire should be there as well. The only difference is that (in my pic above) that pink wire with the spade terminal sticking out was also on the coil. I think that's probably the missing key. So as recommended above, now that I have proper fuel, I'm going to retry running a 12v source straight to the coil to see if that fixes everything.
Old Aug 31, 2022 | 08:23 AM
  #52
Rescue Rogers
Good luck!!
Old Aug 31, 2022 | 06:35 PM
  #53
Muuhaha's Avatar
Muuhaha
Good luck!!
Luck was needed!!! But I decided to trace everything backwards. The R terminal was the r terminal, but for some reason the resistor wire was not sending 12v with key on. When I tested it before it was good, so I'm not sure what happened. Also when I tested last time I had no fuel, so no start again.
So I ran a baby 'key on' 12v jumper to the coil and it started right up!!
I'm not sure what's going on with the resistor wire, but I guess I'll replace that whole harness sometime before the year is out. For now I ordered a few resistors (I'm looking for a 1.5ohm so I've read) and I'm just going to run a key on 12v to the resistor and then to the coil.
Appreciate all the help from everyone on this journey! Now I just have to figure out how to tune this thing haha
