Distributor Refurbish
Old Aug 25, 2022 | 02:33 AM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Default Distributor Refurbish
I want to refurbish my big block distributor. Any thing I need to know when I put it back together?
Old Aug 25, 2022 | 10:55 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
They are a pretty simple arrangement with only a few parts. I've attached Dave Fiedler's paper on the steps to rebuild and how to shim for vertical gap and determine appropriate upper bushing play.
File Type: pdf
Old Aug 25, 2022 | 11:22 AM
stingr69's Avatar
stingr69
Thanks for posting that. I had a distributor torn down for an overhaul and could not find much on the proper procedures and lubes. Added it to my "library".
Old Aug 25, 2022 | 11:46 AM
1969RAY's Avatar
1969RAY
Exactly what I was looking for-thank you for posting! It's the details about lubrication that will make all the difference.
--Steve
Old Aug 25, 2022 | 05:56 PM
Avispa's Avatar
Avispa
Please be sure to check that the distributor drive gear doesn't bottom out on the oil pump drive after you fix it up and get the end clearance trimmed up.
I drove this thing around for 15 years with the gear end clearance at .150 and that's not a typo. It ran perfectly and the timing was rock steady so I just left it alone all that time. I got the thing all shimned up correctly and whatdya know, the gear bottomed out and left the distributor housing off the intake manifold. It took about .130 of nylon washers to get it squared away. All that block decking and line boring did weird things.... lol
Old Aug 28, 2022 | 11:26 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Well, there is "rebuilding" it and then there is "blueprinting" it.
The distributor is the one engine component that is the least understood in a car, and yet is actually the single most important part to get "tuned" correctly to have your car run it's best.
These days it's called setting your distributor curve, in the old days it was called power-tuning, and it was the number one item altered by manufacturers to get engines thru the new emission standards in the 60s & 70s, and those changes started in 1965. 1964 was the last time a chevy left the factory with a great distributor curve.
And it is very possible for you to curve your distributor while it is on the work-bench, and apart, rather than in the car. All you need is a handheld vacuum pump and a protractor.
See my distributor blueprint thread below. That should give you enough ideas that you can do it yourself:
https://www.corvetteforum.com/forums...ing-chart.html
Old Aug 28, 2022 | 05:58 PM
1969RAY's Avatar
1969RAY
Well, At least now I know a shitload of what I don't know and not sure I have the band width to understand it. But it is so interesting the depth of knowledge in this forum...
Thanks!
To Distributor Refurbish
