Msd
Old Aug 25, 2022 | 08:55 PM
bobby70's Avatar
bobby70
Default Msd
HI all walked out to my car 1970 small block to go for a ride will not start so I have a msd 6a box to test it no spark ,so how can you test the msd blaster coil before I buy a new box thanks for your help
Old Aug 26, 2022 | 09:38 AM
wilcar's Avatar
wilcar
What kind of distributor are you using? If hei it could be the ignition control module. Use your old coil if still good and disconnect your "box". Nothing wrong with using your old points distributor if you still have it. Standard Motor Products still has quality ignition parts if you decide to get rid of your hei set up. Do you really need the "box"??
Old Aug 26, 2022 | 12:22 PM
carriljc's Avatar
carriljc
I would just buy a generic gm coil and hook it up to see if it works. And then you'd have a spare.
Old Aug 26, 2022 | 01:41 PM
kossuth's Avatar
kossuth
If you have an 6A box its pretty simple to test the coil. Connect the coil to the coil wires on the box, get power and grounds to the box, hook a spark plug wire or similar to the coil output, and then short the two magnet pickup wires together. By shorting those out the box will trigger and fire off the coil.
Old Aug 26, 2022 | 11:06 PM
bobby70's Avatar
bobby70
Thanks guys I. will try on Saturday
Old Aug 27, 2022 | 08:32 AM
Danish Shark's Avatar
Danish Shark
Also be aware that if the voltage drops down to about 10 Volt while cranking then the MSD box will not fire.
To Msd
