Stock 81 250HP+ Engine Mods Question
Old Aug 26, 2022 | 12:01 PM
jasenr's Avatar
jasenr
Default Stock 81 250HP+ Engine Mods Question
Hello, I was wondering what heads/cam y'all would recommend for a stock L81. I am only thinking about doing this because my stock ones are cracked. I figure while I'm at it, I might as well get a mild bump in hp/tq. I want to keep the stock manifold, carb, and air cleaner along with the stock exhaust manifolds/system. Like I said, I know this won't be optimum, I just like the all factory look. My thinking on heads is to bump the compression up a bit and run premium fuel...? I'd like to get @250+ HP and @300+ TQ and keep the motor looking stock. I freely admit I'm new at this and feel free to tell me if I'm dreaming! Thanks!
Old Aug 26, 2022 | 02:08 PM
Richard Daugird's Avatar
Richard Daugird
Is it a 1981, or an L82 engine in whatever year car?
Old Aug 26, 2022 | 02:13 PM
jasenr's Avatar
jasenr
It's a stock L81 in a 1981 Corvette.
Old Aug 26, 2022 | 02:20 PM
Richard Daugird
Oops, I did not know there was an L81. At 280 ft lbs stock, I'd say it would be possible to get up to 300 with just heads and a cam, even when you choke it up with the stock manifolds.
Old Aug 26, 2022 | 07:12 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
welcome.
you are thinking correctly, raise C/R.
better heads better flow and increased
C/R.
good luck.
your only limit is cam selection.
you need enough vacuum to allow ecu to
work properly
Old Aug 26, 2022 | 08:23 PM
Crimson Thunder's Avatar
Crimson Thunder
I really like those new Trick Flow 175cc Double hump heads. Installing those with a cam around 218 degrees duration at .050 and you will have a nice bump in power that is still fun to drive.
Old Aug 27, 2022 | 09:45 AM
BrandonU's Avatar
BrandonU
Since you want to maintain a stock appearance, I assume you want to use a steel head with drilled ends for your accessories. I would point you towards a Dart Iron Eagle, 180CC head that has an advertised 64cc chamber. These are a nice upgrade from factory. The smaller chamber will bump your compression slightly as well and work better with your low-compression, 4 valve relief flat top pistons. These heads will still use a 1204 intake gasket and a 1404 exhaust, so all your current externals will bolt on fine. I use a lot of Dart IE's in dirt racing engines that require a steel 23-degree head. (much larger runner and more modified of course).
Brandon Unklesbay
All-In Performance, LLC
To Stock 81 250HP+ Engine Mods Question
