Considering upgrading/modernizing elimination the points system. There is Pertronics, MSM, or simply leaving points in there. Not having any issues. Concerned that quality points kits may lose manufactured quality theyce had. For example, I looked at Rock Auto for a quick list and they show 7-8 choices. Not sure what is best. So considering a set it and forget it system Like Pertronics or MSM. Are there preferences (features/benefits) of one versus the other. Two cars a 1972 small block and a 1970 Big Block, both have original engines and neither engine has been modified. Points, Pertronics, or MSM, that is the question? Thanks
Add HEI to your set it and forget it list.
Some bemoan the fact that HEI works until it doesn't. I actually like the fact that it either works or it doesn't. No in between futzing around with settings.
Some will say points are easier to deal with on the side of the road. Granted, but HEI can be too. Just carry a spare module and coil like you would carry a spare points and condenser. In either case a screwdriver gets you on your way in minutes.
Suggest you contact Lars on this forum for his input on the electronic widgets!
post 4 explains it pretty good. it's not a big deal to carry a extra module and coil. i ran a Allison XR700 points conversion for 30 years without any problems. i eventually got the MSD corvette dist because of the easier adjustability of the mechanical advance. the same can be done with a points dist with only a little more effort. here is the way i look at the point conversion kits when it comes to the "works until it doesn't" issue. if they fail there is a 99.967% you are calling a tow truck. pretty much no parts store is going to have replacement parts. almost all parts stores will have points or HEI parts and points rarley if ever fail anyway.
Originally Posted by Sigforty
Keep the points. NAPA echilin cs-786 are the points you want.
Upgrade your stock distributor with a good set of points (CS786) with RR175 condenser. Put a proper curve and tune on it, and you will not be able to find a better ignition system that produces more power or provides better reliability.
Not sure how you could do it better than brass contacts within the cap n rotor - but a set can be had for under $12 @ Rockauto. May not be available in a choice of colors, and hopefully they can't kill quality in something so simple. I always used Accel.
Originally Posted by Cormac87
Now that the decision is made to stay with points, is there a preferred rotor and dist cap p/n’s to utilize?
Again, thank you.
For rotor use the heavy duty NAPA/Echlin RR1670.
For cap, if you don't mind it being tan instead of brown, use the NAPA/Echlin RR1650 High Performance cap. If you want a black cap, use RR165. It still has brass contacts rather than the cheap aluminum but is slightly lighter than the RR1650 - more like the OEM stock cap.
