Rag Joint
Old Sep 6, 2022 | 01:00 PM
VetteMel's Avatar
VetteMel
1st Gear
Default Rag Joint
Help, I replaced the rag joint on my 1972 vette.
Instructions were to disconnect all rag joint bolts, loosen all bolts holding steering wheel/shaft in place, push/pull steering shaft back into driver compartment enough to remove joint.
I have pushed back shaft about a 1/2 inch. installed new rag joint but I am having difficult getting shaft back the 1/2 inch I moved it.
I have tried pulling and even slightly tapping with a hammer against the steering shaft coupling trying to move it.
Does anyone have any suggestions on how to move this shaft down towards coupling the 1/2 inch I need.
Any help would be greatly appreciated.
Old Sep 6, 2022 | 01:40 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome, moved you here
Old Sep 6, 2022 | 03:51 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
VetteMel, I have done this a couple times and have a few pictures that will help. Reply with your email address and I will send you the pictures and explain the process.
Old Sep 6, 2022 | 08:19 PM
kkupec02's Avatar
kkupec02
Welcome.
Old Sep 7, 2022 | 06:32 AM
JavaJolt78's Avatar
JavaJolt78
Go Vette Go,
GR8 post and would like to have that info also if it will apply to my 78...
michael.kane72@yahoo.com
JJ78
Old Sep 7, 2022 | 11:28 AM
Go Vette Go
Originally Posted by JavaJolt78
Go Vette Go,
JJ78
Informtion sent
To Rag Joint
