Distributor Primary Lead Wire Tab?
Old Sep 29, 2022 | 09:42 PM
Aldo J's Avatar
Aldo J
Default Distributor Primary Lead Wire Tab?
Can someone explain the purpose of the copper-colored tab on a distributor primary lead wire? Thank you!
Old Sep 29, 2022 | 10:28 PM
lars's Avatar
lars
It's to prevent the lead wire from slipping through the distributor housing grommet. The wire collar is installed on the top side of the grommet, and the grommet fits the wire so tightly that the collar can't slip through it. This maintains proper "slack" in the wire inside the distributor.
Your lead wire grommet in the distributor should look like this. The "pointy end" installs downwards. This grommet seals tightly against the wire, and the "anti-slip" collar on the wire cannot pull through the grommet:
Lars
Old Sep 30, 2022 | 06:06 AM
Aldo J's Avatar
Aldo J
Lars
Thanks, Lars.
To Distributor Primary Lead Wire Tab?
