Remove trim rings for wheel alignment?
Old Oct 7, 2022 | 12:04 PM
DRC's Avatar
DRC
Default Remove trim rings for wheel alignment?
I have the correct four clip trim rings, once on prefer to not take off. Planning on getting four wheel alignment, can the trim rings stay on?
And, any good alignment shops in central Jersey?
Tks. Doug
Old Oct 7, 2022 | 12:06 PM
lars's Avatar
lars
No, the rings have to come off. The alignment tools have to clamp onto the bare wheel, and cannot be clamped to the trim rings.
Lars
Old Oct 7, 2022 | 12:41 PM
DRC's Avatar
DRC
Lars
Thanks Lars.
Also, thanks for your Qjet tuning and choke setting writeup. My 73 L48 4 speed (dead bone stock with emissions equipment, plus I did distributor recurve) starts per owner manual. Depress accelerator (cold), release, turn key, starts immediately. Fast idle 1,300 rpm.
Tks. Doug
Old Oct 7, 2022 | 12:42 PM
lars's Avatar
lars
Good job on the work, Doug!
Isn't it remarkable how nicely these cars run if you simply set them up correctly and do good work instead of hacking them..?
Lars
Old Oct 7, 2022 | 12:54 PM
DRC's Avatar
DRC
Lars
Yes. I also had my 64 Impala SS 327 300 original AFB start one click of the key. I always work until all my cars start and run per owners manual / service manual. I was taught many years ago by my father and grandfather to read service manuals and understand how things are designed to work. And your input over the years is much appreciated.
Tks. Doug
Old Oct 7, 2022 | 02:49 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie question:
Would it be better to take the trim rings off before the alignment (to prevent the tech. from bending the trim rings while removing and reinstalling them)?
Old Oct 7, 2022 | 02:52 PM
walleyfisher's Avatar
walleyfisher
Originally Posted by doorgunner
Rookie question:
yes 100%
Can guarantee they will alt least ding them putting them back on
Old Oct 7, 2022 | 08:21 PM
Crimson Thunder's Avatar
Crimson Thunder
They left mine on last time. They said the new sensors attach to the top of the rim.
Old Oct 8, 2022 | 12:00 AM
Eric P's Avatar
Eric P
My rim clamps attach on the outside of the rim too on my alignment machine but I would want them off too
Old Oct 8, 2022 | 09:02 AM
BKbroiler's Avatar
BKbroiler
If you don't mind driving to Hackettstown, there is a shop called Dimension Auto Repair that does alignment work on all kinds of 60s and 70s cars. They did my friend's 69 Vette and my 77. You can trust them with your car.
Old Oct 8, 2022 | 11:22 AM
68blvert's Avatar
68blvert
Depends on the alignment machine. Some clamp to outer edge of rim bead, some to the inside. Mine actually clamps to the tire itself. Doesn’t touch the rim at all. Reduces the risk of scratching someone’s $4,000 set of rims.
Old Oct 8, 2022 | 11:57 AM
pspicci's Avatar
pspicci
Same here. The place that does my alignment has the machine that clamps to the outer tire. Don’t have to mess with the trim rings.
Pat
To Remove trim rings for wheel alignment?
