Extremely hot ignition coil
https://www.npdlink.com/product/resi...on-coil/101401
It is only $22, but it is for a Ford, and would be continuing the wiring "mods" you already have.
This complete engine bay wiring harness is looking more attractive:
https://www.topflightautomotive.com/...-block-manual/
It is a little more, at $263, but I have seen too many fiberglass corvettes that have melted down due to bad wiring.
Maybe consider it cheap insurance.
I never did find the fabled resistor wire. That I didn’t find it means it’s been removed. Though from what I recall the car has the original points distributor, I believe at some time in the car’s past someone installed an HEI but then the points distributor was reinstalled without correcting the wiring.
Concerning the pink and tan wires out of the fuse block, after removing the vent pipe I got an up close look at the wires and both of those disappear into the original wiring harness that’s never been tampered with. The car has rear window defrost so maybe those wires have something to do with that. At any rate, I’ll definitely check the coil voltage before firing the engine.
I’ll be ordering g a new LL harness in the next few days. This car has always been dead reliable and it needs to be that way in the future. If either of Ms. mudbone’s car or my truck is in the shop the ‘72 is the back-up.
I think the picture below shows how the ignition and forward harnesses slide together before they are screwed to the bulkhead.
When endeavoring a project like this understanding these details can save loads of time.
Here’s the bulkhead connector:
There’s obviously a couple of open holes. Maybe someone can point out where the resistor wire is supposed to be found.
Interior = $1,000
Brake System = $1,000
Suspension = $1,000
Differential/DriveShaft(s)/Trailing Arms/Parking Brake/ (DIY Rebuild All Components) = $1,000
New Chrome = $1,000
New Tires & Trim Rings = $1,000
Engine & TH400 A.T. DIY Rebuild =$1,000
(Items I forgot about $1,000)
Also, what is the black wire coming out of the firewall with the green wire attached to it? You can see one of them has had the connector taken off it so it’s hard to know what to do.
the TCS is disabled in this car so if the wire is apart of that system it won’t be plugged in.
I like the gauge wire sizes that are added. Thank you Wilcox!
So your black & green wire is probably more of the temp switch wiring?
The diagram references black and white wires that I suspect being the alarm but it doesn't address the green wire. If I can get this connection addressed I believe I'm ready to begin testing as soon as the frozen tundra thaws out. The weather in central Kentucky thinks it's January.
Here’s what I’ve got right now:
Cranking voltage at coil: 8.9
”Key on” voltage at coil: 6.45
Temperature at coil after car was well up to temperature after setting dwell on new points: warm but I could hold on to it all day.
The one hurdle I didn’t anticipate was the dwell on the new points was so far off the car wouldn’t hit a lick when I first tried to get it started. The point gap wound up being too large. My advice to anyone packing an extra set of points would be to install new points, get the dwell set and throw the previously installed set in the small bin between the seats. You’ll notice I didn’t say glove box.
Many thanks to all of those that participated. I doubt I would have solved this one without this forum.
Now, on to replacing the left front brake caliper for the fourth time. If there’s another Corvette in my future I’ll never purchase brake calipers from local parts houses again.
