76 steering Column
Old Nov 4, 2022 | 04:06 PM
GaryInArizona's Avatar
GaryInArizona
Default 76 steering Column
Does' any know if a 71 column will work on a 76?
Old Nov 4, 2022 | 04:10 PM
Greg's Avatar
Greg
Just another Corvette guy
Yes it will.
Old Nov 4, 2022 | 04:22 PM
alleyesonthefuture's Avatar
alleyesonthefuture
Default Column
Would there be any issues with the wiring/pinout with the later harnesses? Especially 77-up?
Old Nov 4, 2022 | 06:47 PM
GaryInArizona
Thank you.
Old Nov 4, 2022 | 07:02 PM
Greg's Avatar
Greg
1977 uses a different column, wiring and switching setup.
Old Nov 7, 2022 | 10:04 AM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
A 71 and 76 column is the same with the exception of the steering wheel and hub assembly. You can backdate the 76 with the hub and upper cover from a 69-75 or you can bolt in a 69-75 column. 77 is where is all changed and the 77 column is by itself, then you have the 78-82 column with just some minimal changes to them.
Old Nov 7, 2022 | 07:27 PM
GaryInArizona
Ok thanks for info I just bought a 72 column from a forum member so it should boult in my 76 ?
Old Nov 8, 2022 | 06:46 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yes, it will bolt right up. Only that awful 76 only Vega wheel won't fit.
Old Nov 8, 2022 | 08:07 AM
Bills17n72's Avatar
Bills17n72
yep!
Old Oct 13, 2023 | 11:15 PM
Limelight68's Avatar
Limelight68
Cruising
The Ididit quote for a custom shortened 68 retrofit column is $1136 - a $200 premium to have them shorten the column. I'll probably go ahead and do it seeing as how @Ron1968 said it was such a pain in the *** to customize himself Also, Ron - what adapter is that for the steering wheel?
To 76 steering Column
