Dewitt radiator install
Old Nov 21, 2022 | 08:25 PM
Sheet1234's Avatar
Sheet1234
Default Dewitt radiator install
Good Evening, Folks hope all is well.
Installing a dewitt radiator with spal fans in my 1973 corvette auto. The radiator is sitting nicely in the core, the core is bolted down with 2 bolts at the bottom of he core, and the right and left clips on top of the core are installed
Other than hooking up the radiator hoses and radiator transmission lines, is there any other support for the radiator core?
Thanks, Reggie
Old Nov 22, 2022 | 01:29 AM
ChaseC4Vette's Avatar
ChaseC4Vette
So other then the bolts and the linement that it sits on you should be good it sits sturdy so make sure there’s no wobble once it’s bolted and tightened if so you’re good to go!!
Old Nov 22, 2022 | 05:54 AM
Mr D.'s Avatar
Mr D.
The radiator is sitting nicely in the core, the core is bolted down with 2 bolts at the bottom of the core, and the right and left clips on top of the core are installed
I'm assuming you have installed the side bolts, two (upper & lower) on each side of the core support.
Old Nov 24, 2022 | 02:27 AM
Z51JEFF's Avatar
Z51JEFF
There is a rod support that runs from the bottom center of the support to the front of the car,one support about 12 inches long. I put a Dewitt's in my 75 and the lower trans cooler line was really close to the frame so I shaved off about 1/4 inch of material on the frame.
Old Nov 27, 2022 | 11:46 AM
ignatz's Avatar
ignatz
Originally Posted by Z51JEFF
There is a rod support that runs from the bottom center of the support to the front of the car,one support about 12 inches long. .....
I have a picture of that support. Of course you have new rubber vibration and shock insulators in the top and bottom supports, right?
Old Nov 27, 2022 | 06:04 PM
Z51JEFF's Avatar
Z51JEFF
Thanks fir reminding me,those rubber isolators were a total pain in the *** to get everything together,ended up cutting a lot of the rubber away.
Old Nov 27, 2022 | 07:47 PM
Reggie Hohenberger's Avatar
Reggie Hohenberger
6th Gear
Thank you
Old Nov 27, 2022 | 07:51 PM
Reggie Hohenberger
6th Gear
Default Sheet1234
Yes, i have the Dewitt rubber cushions that fit in the brackets
To Dewitt radiator install
