replacing harmonic balancer
Old Dec 10, 2022 | 05:18 PM
Sidneyhop454's Avatar
Sidneyhop454
Default replacing harmonic balancer
1970 454 garage car that Im working on but run the engine every few weeks to keep the engine fresh.
I was getting a constant screeching with my belts and eventually the WP belt broke. Screeching continued with the PS belt so I just removed it to get rid of the annoyingness of it. Notice a distinct vibration at around 2-3k rpm and can see a slight wobble of the crank pulley.
Can a spun bearing cause a wobble like this of the pulley?
Can a bad harmonic balancer cause bearing damage?
Can pulling and replacing the balancer be done with the engine in the car and the radiator/shroud in place?
Its a stock balancer. Any recommendations for a better replacement?
I haven't measured it yet, is it a 7" or 8"?
Old Dec 10, 2022 | 05:33 PM
Avispa's Avatar
Avispa
Spun rod bearing won't cause crank pulley wobble
the crank rotates in the main bearings, which will keep it straight. You balancer could have failed at the rubber ring between the hub and the inertia ring. That would account for wobble and vibration.
Taking the ting off w the radiator and shroud in place will be tough. There's not a lot of room for the puller if the shroud is in place.
Stock balancer is good. IIRC, it's an 8 inch.
Old Dec 10, 2022 | 10:37 PM
Sidneyhop454
OEM balancer is internally balanced right? Will an aftermarket externally balanced one throw it off? Would it be recommended to remove the weight to bring it to '0'?
Im looking at this one as a replacement.
ATI 917740 Super Damper Harmonic Balancer
Old Dec 11, 2022 | 01:21 AM
Avispa's Avatar
Avispa
There are OEM balancers for 396/402/427 and they are all indeed for internal balance engines. There is a 454-specific unit that is externally balanced. That's the one you need. Check the mfrs data to be sure you get the right one if you're going aftermarket.
The ATI damper you're looking at seems to be the right one for a 454.
Old Dec 11, 2022 | 11:10 AM
lars's Avatar
lars
Just because the pulley is wobbling doesn't mean there is any problem with the balancer. Bent pulleys are common. Remove the pulley from the balancer and then turn the engine over while watching the actual balancer. I'll bet it's fine. The pulley is bolted to the inner part of the balancer, which will not wobble when the balancer outer ring fails. Don't assume a problem where none exists. The balancer is not causing your wobble problem.
For info on what a slipped balancer looks like, and the replacement process (photos are for a small block, but BB process is the same), see my post here:
https://www.corvetteforum.com/forums...blem-post.html
Post #36 shows re-assembly.
Lars
Old Dec 11, 2022 | 11:56 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
is the pulley loose and it causing the wobble and belts screaching...check that first...if the harmonic balancer bolt fell out, or snapped and the balancer is walking off then it could be and issue....if you are playing in the front of a big block and you want to remain sane.....you should mark the hinges location on your hood, pull the hood, disconnect the radiator support upper bolts and loosen the lowers, disconnect the upper hose and tilt the support forward away from your motor...
Sidneyhop454
Lars
I haven't pulled the pulley yet and will but here's a quick video of the damper and pulley currently.
There's a noticeable vibration that's new with the engine that seems to coincide with the wobble. Could this be a crank issue?
https://drive.google.com/file/d/1Ot-...w?usp=drivesdk
Old Dec 11, 2022 | 11:58 AM
Sidneyhop454
Ill check this. Thanks
Old Dec 11, 2022 | 12:21 PM
lars's Avatar
lars
The camera is wobbling pretty bad, but I'm not seeing any wobble of the balancer itself. Looks like the pulleys have some runout, but I'm not seeing balancer wobble other than a bunch of camera wobble...
Old Dec 11, 2022 | 12:53 PM
71 Green 454's Avatar
71 Green 454
I don't see any wobble either but the sound is weird, like a scrapping sound that I wouldn't expect to hear. Maybe the timing chain rubbing against the timing chain cover? Do you know if the timing chain set is original?
Are your pulleys lined up straight when belts installed?
Old Dec 11, 2022 | 01:24 PM
Sidneyhop454
Heres another shot without the pulley. I tried to limit the wobble as much as possible.
https://drive.google.com/file/d/1P2z...usp=share_link
Also a closeup of the damper
https://drive.google.com/file/d/1PG2...usp=share_link
Old Dec 11, 2022 | 01:27 PM
Sidneyhop454
Yeah...Im hearing an odd noise too that picks up around 2k to 3k rpm. A noticeable vibration also.
Could a bearing going bad cause this?
Old Dec 11, 2022 | 01:36 PM
lars's Avatar
lars
You don't have a balancer problem unless you can verify that the outer ring has slipped without lateral movement. You have a bent pulley - not a bad balancer.
Highly unlikely. Bad bearings will cause a noticeable and audible "knocking" sound.
Old Dec 11, 2022 | 02:48 PM
Sidneyhop454
ok thanks for the info. Ill update this post as things progress.
Old Dec 12, 2022 | 09:39 AM
derekderek's Avatar
derekderek
Check the water pump, alt and power steering for seized pulleys. Most common cause of screeching and burning up belts in very short order.
Old Dec 12, 2022 | 10:45 AM
Sidneyhop454
This is what I initially thought was happening. Belts are removed and those spin freely.
To replacing harmonic balancer
By Michael S. Palmer | 2026-06-03 11:00:24
