Terrible Idle. What’s wrong.
Old Dec 17, 2022 | 11:32 PM
OldCarBum's Avatar
OldCarBum
Originally Posted by CarterDawson
Thank You. I’ll try to figure it out myself first, but if I don’t get anywhere I will. I’m out of town so I won’t be able to work on it for a few days.
You are braver than I am!
Years ago I attempted to rebuild a couple of QJets that were original to two of my cars.
They looked pretty and I used the GM rebuild kits but, I ended up butchering the rebuilds so bad I ended up tossing them and buying new ones.
This was back when you could walk into a GM dealership and buy the correct new part over the parts counter.
If you are unsuccessful send it to Lars, and don’t bend or toss anything, even if it comes with a new part in the rebuild kit.
Good luck!
Old Dec 18, 2022 | 11:21 AM
ddawson's Avatar
ddawson
Nice last name LOL.
When I buy a car the first thing I do is go though it.
Carb goes off for service because you never know who messed with it.
Change the plugs and wires, address the distributor if points.
Then you can set the timing knowing everything should be in good working order. I also check all the rubber lines for leaks because you can chase that for days,
Old Dec 18, 2022 | 05:36 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Send it to Lars you won’t be disappointed.along with all
the other problems you may find.
Old Dec 19, 2022 | 11:38 AM
lars's Avatar
lars
Originally Posted by ddawson
When I buy a car the first thing I do is go though it. Carb goes off for service because you never know who messed with it. Then you can set the timing knowing everything should be in good working order
Dan -
Actually, you always want to do it the other way around: If you can get the engine running at all, always set the timing up first before you ever touch the carb. As I say half-jokingly, "90% of all carb problems are ignition problems." It's not far from the truth. You cannot tune a carb to compensate for timing problems, so you want to make sure timing and ignition are spot-on before doing any carb work. Also, keep in mind that the timing affects the carb, but the carb does not affect the timing. Attempting to get a carb running well before the timing has been correctly set up will result in chasing your tail all over the place. So always set up the timing first, and then do the carb work. It will make your carb tuning and setup much easier. If it doesn't run well, you will then have more confidence that the issues actually lie with the carb and not with the timing.
Lars
Old Dec 20, 2022 | 06:47 PM
Peterbuilt's Avatar
Peterbuilt
Ask Lars to send you his Technical Information Bulletin on:
How to set your timing for peak performance.
