Broken Console Tabs
Old Feb 8, 2023 | 09:37 AM
76yellow's Avatar
76yellow
Default Broken Console Tabs
The tabs on my center console are broken off so I can't mount the shifter plate ! Anyone have any clever ideas to fix this problem without buying a new console ?
Old Feb 8, 2023 | 09:45 AM
66RAY's Avatar
66RAY
Check the vendor sites for the repair kit. Easy to do and not crazy expensive.
Old Feb 8, 2023 | 10:09 AM
sunflower 1972's Avatar
sunflower 1972
Old Feb 8, 2023 | 07:18 PM
Mooser's Avatar
Mooser
Repro console didn't fit right so I Bubbafied the old one that did.
A couple of pieces of aluminum, drilled holes to allow the glue to go through, scuff everything up good and JB weld under/over and around.
Let it dry and use the shifter plate as a guide where to drill the holes and install the clips that match the screws.
M
Old Feb 8, 2023 | 08:24 PM
76yellow's Avatar
76yellow
Some great fixes .....I can make those brackets myself ! Thanks guys !!!!
To Broken Console Tabs
