Ebay Coilover's
Old Feb 13, 2023 | 03:22 PM
joserpaq's Avatar
joserpaq
Default Ebay Coilover's
Hello All,
I've been waiting to replace my front shocks and springs with a coilover setup to better dial in the cars stance. I looked at these on ebay and just got an offer from the seller to purchase these at $386 was seems like a good deal but maybe too good to be true.
Has anyone tried these?
https://www.ebay.com/itm/25526018389...&ul_noapp=true
They are from a company Helix Suspension Brakes & Steering https://www.helixsuspension.com/cata...ng-Accessories
Old Feb 13, 2023 | 04:19 PM
MelWff's Avatar
MelWff
You are sure you want a spring that stiff, 500lbs?
Old Feb 13, 2023 | 04:47 PM
joserpaq's Avatar
joserpaq
That’s a good point. What should they be for street setup with SBC?
I just drive around town on weekends so biggest complaint aside from improving stance is over steer which I don’t think these will help. I don’t have a rear sway bar which I understand can help with that. So I’m doing that as well.
Old Feb 13, 2023 | 04:58 PM
Richard Daugird's Avatar
Richard Daugird
Those are about half the price of QA1 or Viking. Doesn't look like the compression/rebound is adjustable, which maybe doesn't matter for a cruiser anyway. Go for it and let us know how they work out for you.
Old Feb 13, 2023 | 05:10 PM
MelWff's Avatar
MelWff
For your driving, I would say 450.
You mention stance, that can be things other than springs. What size front and rear tires? What does the rear look like, are the half shafts parallel to the ground or higher on the differential end or wheel end?
Old Feb 13, 2023 | 05:54 PM
Richard Daugird
I haven't done my rear coil overs yet, just the front. Pulled out a rear leaf or two. Made a Hell of a difference. 255/60s all around.
Old Feb 13, 2023 | 06:00 PM
joserpaq's Avatar
joserpaq
Top of Front drivers side tire to wheel well clearance is smaller than passenger side. I replaced the spring but still sits the same.
Old Feb 13, 2023 | 06:02 PM
MelWff's Avatar
MelWff
I have same thing I see in your pic. Top of Front drivers side tire to wheel well clearance is smaller than passenger side. I replaced the spring but still sits the same.
A bad or misadjusted rear spring will effect the front
Old Feb 13, 2023 | 06:44 PM
Richard Daugird
That is a before and after picture, it is roughly the same side to side. If the side to side difference were that massive, there would be serious problems!
To Ebay Coilover's
