78 Rear Leaf Spring Problem
Old Mar 2, 2023 | 10:56 AM
89vette's Avatar
89vette
Default 78 Rear Leaf Spring Problem
I'm helping my father on his 78 SA that he bought new and has a renewed interest to drive. The rear of the car sags and I was looking into options for replacing the rear spring. I now know that in 1978, the spring went to 2 1/2" wide with 7/16" bolts and his has the 7 leaf HS suspension. I cannot find a replacement anywhere. Does anyone know who might have one? The 2 1/4" 63 to 77 springs are available but no one has been able to tell me if it will fit. I assume it would need spacers.
Old Mar 2, 2023 | 11:02 AM
speedreed8's Avatar
speedreed8
Try Detroit spring.com. (Eaton). $300-400. 2 1/2 wide.
Old Mar 2, 2023 | 11:22 AM
kodpkd's Avatar
kodpkd
If you like to work on these kind of things, you might try to rebuild the spring. Take it all apart, clean it up, repaint it with gray galvanizing paint, add the leaf spring liners. This could lift it a little bit. If they are not to sagged out, you can adjust the spring end bolts or add a little longer bolt. Have some fun and save money.
Old Mar 2, 2023 | 02:34 PM
interpon's Avatar
interpon
see link
https://www.corvetteforum.com/forums...af-spring.html
Old Mar 2, 2023 | 03:52 PM
89vette's Avatar
89vette
Here is what I THINK I know based on my conversations with suppliers:
In 1978, GM went from a 2 1/4" spring with 9/16" mounting bolts to a 2 1/2" spring with 7/16" mounting bolts. All 63 to 77 cars had the narrower spring. The 7 leaf was the HD option and the 9 leaf was the standard option. I stiff have yet to find a supplier for the 2 1/2" wide 7 leaf spring. There is not one listed on the Detroit Spring website. No one has yet to say if you can use the narrower spring on the 78 and if you would need spacers.
Old Mar 2, 2023 | 04:17 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
78s and 79s that had factory gymkhana springs used a 2 1/4" wide spring in the 2 1/2" carrier and shims front and rear.
If your 78 originally came with the gymkhana spring the shims should be there.
Altho when I purchased and drove my white 79 home 1100 miles I found this!!
Old Mar 2, 2023 | 04:23 PM
KapsSA's Avatar
KapsSA
77-79 Rear Spring Spacer Plate - With Gymkhana Suspension (corvettecentral.com)
Old Mar 2, 2023 | 04:25 PM
89vette's Avatar
89vette
Ahhh! This is coming together then. The car does have the Gymkhana suspension and it does have the shims. So Eaton does have the correct spring as part number ML715 2 1/4" width, 7 leaf stock ride height.
Thank you!
Old Mar 2, 2023 | 05:39 PM
interpon's Avatar
interpon
Thank you!
stock was 6 leaf gymkhana..eaton will be 7..note my link and see how mine fit, had to remove one plate. Watch bolt length…you need spacer plate too if yours is still there on 2 1/4…or not…pic of center of spring.?
Old Mar 2, 2023 | 05:55 PM
89vette's Avatar
89vette
Here is a picture. It does look like 6 springs but I wasn’t sure if the 7th was on top and out of view.
Old Mar 2, 2023 | 05:58 PM
89vette's Avatar
89vette
Can you confirm the bolt size?
Old Mar 2, 2023 | 06:02 PM
interpon's Avatar
interpon
Your spacer is here..watch you length of bolt to not crack case. Note carefully washers as mine had some double..i replaced mcmaster carr in thread.
Old Mar 2, 2023 | 06:24 PM
89vette's Avatar
89vette
which leaf did you remove? I understand on the bolt lengths. I’ll make sure the new ones match the old ones. I was told they are 9/16 bolts on 78’s.
Old Mar 2, 2023 | 06:30 PM
interpon's Avatar
interpon
It was a spacer not a leaf..take a look at the thread
Old Mar 2, 2023 | 06:47 PM
grantstigers's Avatar
grantstigers
I may have a brand new one 7 leaf, I will check when I get home if you are still interested
not new but very lightly used
195.00 shipped
Thanks, grant
Old Mar 2, 2023 | 07:25 PM
89vette's Avatar
89vette
oh ok. So you replaced the stock 6 leaf with the Eaton 7 leaf and it was a tad wider so you used only one of the 2 spacers right?
Old Mar 2, 2023 | 07:29 PM
89vette's Avatar
89vette
Thanks, grant
Now I’m thinking that I need a 6 leaf that is 2 1/4” wide since that’s what it came with. I’m thinking that the original 6 leaf gymkhana setup isn’t available any other. So I have to use a 7 leaf that might be a tad wider and eliminate one spacer.
To 78 Rear Leaf Spring Problem
Old Mar 2, 2023 | 07:56 PM
interpon's Avatar
interpon
buy the 7 leaf..noone makes a 6..even gm replacement was 7.it is NOT wider..same 2 1/4, the 9 leaf is 2.5
Use both spacers for 2 1/4 wide
Old Mar 2, 2023 | 08:27 PM
89vette's Avatar
89vette
this is what is confusing me. you said you had to remove one plate.....
Old Mar 3, 2023 | 01:44 PM
grantstigers
Default 7 leaf spring
Not sure if you are interested in the 7 leaf I have but I did send you a pm
Thanks, grant
