Push Rod damage
Old Mar 6, 2023 | 11:02 PM
  #41
joserpaq's Avatar
joserpaq
Originally Posted by HeadsU.P.
Going back to post 4 photo, unless you cleaned those heads with a shop towel, they are way too dry for my liking. Should be some puddles here & there.
My money is lack of lube top side as the culprit.
When you prime it later with the tool and a HD drill, that will tell you what's going on upstairs. You can jog the IGN key every so often to get all 16 lifters oil fill hole lined up with the oil galley in the block. That will build up some pressure up through the pushrod, hopefully. Don't expect a gusher come out of the pushrod, but there should be a dribble at all 16 rockers eventually. Also, slotted rocker ***** do seem to keep the rocker arm well lubed as opposed to std.
I think this is just a case of a rocker running dry, got really hot until the metal stud fatigued and failed. And if that is the case, the lifters did not supply oil for some reason.
I did clean up that area with a rag but I plan on priming the new oil pump I'm putting in and making sure that I have plenty of oil
Old Mar 6, 2023 | 11:16 PM
  #42
1Hotrodz's Avatar
1Hotrodz
Didn't read all the posts but lifter side of pushrods look better than rocker side. which would indicate lifter side was getting some lubrication but still not enough. rocker side looks very dry even the head itself looks dry. So why no upper oiling? Were the lifters completely bottomed out?
Old Mar 7, 2023 | 02:14 PM
  #43
joserpaq's Avatar
joserpaq
Not sure what happened. Since the damage is accross all the rods to varying degrees I can't blame it on one bad lifter. I set the lash at 1/2 a turn so I don't think it could have bottomed out. I plan on checking oil flow, ensuring proper lash and rocker geometry before putting it back together with hardended rods and new rockers. Beyond that I don't know what else I can do. I did order a new high volume oil pump as well.
Old Mar 8, 2023 | 07:01 PM
  #44
joserpaq's Avatar
joserpaq
I have a question that I hope someone can answer. Can I use self aligning rockers with guide plates and hardened push rods? If not am I better off with guide plates and non-self aligning rockers or no guide plates and self aligning rockers?
Old Mar 8, 2023 | 08:01 PM
  #45
HeadsU.P.'s Avatar
HeadsU.P.
One or the other. Not both.
Self align are for those that prefer not to use guide plates. You are better off with the plates.
You also need to address the stud hole threads. Maybe clean them out with a thread chaser. Then use a thread sealant on the rocker studs because they are exposed in the Intake runners.
When you install your guide plates, just snug them down for now. Install two pushrods & rockers, then check the alignment of the rod in the slot. The plates can be moved up / down & sideways.
When both Exh & Int rods are aligned perfect, remove rockers and torque the studs to specs. Move to the next cyl repeat.
Old Mar 8, 2023 | 08:15 PM
  #46
joserpaq's Avatar
joserpaq
Thanks. I did order both rocker types self aligning in a 1.6 and non-self aligning in a 1.5. The guide plates are not lining up so I'd have to see if just moving them around gets me over the valve stem. I planned on using some RTV to seal the stud nearest the intake that is open to the intake.
Old Mar 8, 2023 | 08:18 PM
  #47
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I believe the plates are more stable but here's the rub....some aftermarket heads have a shift in the intake rocker to provide pushrod clearance as the port gets larger.....the self aligning rocker is a easier bet on this....if not...you sometimes need a split guide plate to shift the intake rocker over and these can sometimes be tricky to setup....at the engine shop years ago, we would set them up, number them and weld them in that position....
I just did a set last week on a 383 and it took about an hour of straight time....I use a brass rod and a small drift to do this...
Self aligning rockers are bolt on and go.....
They work because they made their debut on the infamous LT4 Vette engine.....good for what you can throw at them....the LT4 rockers were a full anodized roller from the factory.
Using both is redundant but would not harm anything as long as one is not binding the other.
Jebby
Old Mar 8, 2023 | 08:23 PM
  #48
HeadsU.P.'s Avatar
HeadsU.P.
With the 1.6 rockers, its critical to check bottom of valve spring retainer to top of valve guide for a minimum clearance. I don't remember your cam lift but if those two parts crash, it could get really ugly.
Off hand, don't remember that minimum gap. Someone will chime in. Use a feeler gauge when valve is fully open.
Bottom of retainer > top of valve guide.
Old Mar 8, 2023 | 08:25 PM
  #49
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Minimum retainer to guide clearance is .060
Jebby
Old Mar 8, 2023 | 08:31 PM
  #50
joserpaq's Avatar
joserpaq
Jebby
Thanks Jebby. I'm concerned that my previous Rod issue may have been worsened by bad rocker lash setup and that would be deadly with self aligning rockers so I'm not sure which way I will go. Can you recommend what you think would be the best procedure to set 0 lash and how much turn you use after zero lash?
Old Mar 8, 2023 | 08:52 PM
  #51
joserpaq's Avatar
joserpaq
Thanks HeadsU.P. - I had 1.6 stamped roller tips previously and checked the clearence and had no issues. The lift for my cam .480 so 1.6 wasn't and issue.
Old Mar 8, 2023 | 09:04 PM
  #52
Jebbysan's Avatar
Jebbysan
Dr. Detroit
With each cylinder at TDC….spin the loose poly loc nut with your fingers to verify it is free….tighten with thumb and forefinger until you JUST feel the lash taken up and starting to plunge the lifter….you will feel the slight resistance as this happens- THIS IS ZERO LASH….from there, one half turn…
Jebby
Old Mar 8, 2023 | 09:38 PM
  #53
joserpaq's Avatar
joserpaq
Jebby
thank you. Challenge is getting TDC for each cylinder since I don't have quandrant marked on harmonic balancer. It's basic balancer with only Cyl 1 TDC mark
Old Mar 8, 2023 | 10:01 PM
  #54
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Blow thumb off #1....you can blow the thumb just by turning the crank with a bar......mark the balancer in 90 degree sections.....each time you move the balancer 90 degrees....that is the next TDC in the firing order 1, turn, 8, turn....etc.....
Jebby
Old Mar 10, 2023 | 06:54 PM
  #55
joserpaq's Avatar
joserpaq
Hello All
I got the rockers and rods installed today. I set the lash pre-load at 1/2 turn and the car started right up running very smooth. I ran it set the timing and took off valve covers to confirm that they have plenty of oil. The car is running great under regular throttle but when I hit the throttle it doesn't have any power and has a backfire. I changed the oil pump to a high volume pump since I was concerned about oiling issues and my oil pressure is now 60-65lbs on cold idle versus 40lbs previously. When the car is warm and rev's up the oil pressure is up around 65-70lbs. Could the loss of power when I hit the throttle be related to a valve hanging open due to high pressure in the lifter not allowing it to properly close with that lash?
Tomorrow I plan to do a compression check as is and then again with the valves loosened to see if I get a difference in compression. Not sure what anyones thoughts or suggestions might be.
I really appreciate it!
Old Mar 10, 2023 | 07:43 PM
  #56
speedreed8's Avatar
speedreed8
I had to reset my Howard’s hyd. lifters to 1/4 turn for the same reasons. After a valve seal change. Backfire and low power after warm up. I don’t know what lifters you have but mine had a short preload
Old Mar 10, 2023 | 07:47 PM
  #57
gkull's Avatar
gkull
I think that you need to use thinner oil.
To Push Rod damage
Old Mar 10, 2023 | 09:00 PM
  #58
joserpaq's Avatar
joserpaq
im using 10-30.
Old Mar 10, 2023 | 09:02 PM
  #59
joserpaq's Avatar
joserpaq
I’m using comp cams lifters. Didn’t have this issue with old rockers, rods and pump. Hopefully that’s the issue.
Old Mar 10, 2023 | 09:23 PM
  #60
speedreed8's Avatar
speedreed8
I rebuilt the engine in 2010 but didn’t remember how I set the initial lifter settings. But after seal repair and setting them as most do at 1/2 turn it ran terrible and I remembered and reset to 1/4.
been running fine since then 2021.
