C3 exhaust recommendations
Old Mar 8, 2023 | 03:30 PM
Mike Fricker's Avatar
Mike Fricker
8th Gear
Default C3 exhaust recommendations
Afternoon all .....
Going to change out the exhaust on my 68'/427 4 speed convertible.
I am looking for a deep throaty sound .. nothing raspy or tinny ...
Car has headers already so looking for a collector back system.
Looking for suggestions/videos of what folks are using.
Thanks in advance as always
-Mike
Old Mar 8, 2023 | 04:31 PM
sunflower 1972's Avatar
sunflower 1972
Can't go wrong with these guys: https://www.corvettecentral.com/sear...haust&count=18
Go with the Magnaflow mufflers.
Old Mar 8, 2023 | 05:22 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Another vote for CC. Nice idle, no drone but when you stand on it it barks. And good fit, also.
Old Mar 8, 2023 | 10:18 PM
forman's Avatar
forman
I bought the n-11 from corvette central already fully welded up ready to go
Old Mar 9, 2023 | 01:23 AM
ddawson's Avatar
ddawson
No collector back system systems. All will need custom pipes from the collector to the section where it passes though the frame.
Too many variations from the different header manufacture.
Old Mar 9, 2023 | 08:29 AM
BKbroiler's Avatar
BKbroiler
This is true. You will need some custom exhaust work on the pipes that attach to the collectors.
Old Mar 9, 2023 | 09:21 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Pypes supposedly makes a collector back setup but heard it isn't worth the trouble.......
Jebby
Old Mar 9, 2023 | 01:12 PM
SteveG75's Avatar
SteveG75
Get the mufflers you want and find a good custom exhaust shop to bend up the pipes. You will be ahead of the game.
Old Mar 9, 2023 | 04:22 PM
Richard Daugird's Avatar
Richard Daugird
Sidepipes!
Old Mar 9, 2023 | 05:57 PM
gkull's Avatar
gkull
Any quality muffler shop. The best option is a different transmission cross member that is made for a straight back pass under three inch full length. With some kind of H or X pipe cross over. Then what ever 3 inch in and out diameter mufflers out back.
I have 3.5 inch in and out mufflers for the least amount of back pressure to 4 inch chrome straight back tips off mufflers.
Deep sound and great for my bored out 427
Old Mar 9, 2023 | 08:34 PM
OldCarBum's Avatar
OldCarBum
Depending on your 427 engine build, 2.5 inch for stock or mildly built or 3.0 inch for any big horsepower and torque build.
An H or X pipe will improve scavenging and slightly improve bottom end performance, however it will change the exhaust tone to a more exotic car sound, and you may loose some of the old school true dual exhaust tone you may prefer.
Buy good flow through mufflers like Magnflow for the deep tone and better performance.
Stay away from the raspy, tinny chambered mufflers that are common for droning.
Old Mar 10, 2023 | 10:12 AM
Mdbirk's Avatar
Mdbirk
Just get you a pair of thrush rattlers single chamber mufflers.
https://www.thrushexhaust.com/video-...eo=r_YL9MPgyrY
Old Mar 10, 2023 | 11:04 AM
Hopper12's Avatar
Hopper12
Hey OP, where do you live. Long shot, but if you're anywhere near the SLC area I have a setup I took off of our '68 L71 that I'll give to you. Magnaflows, great pipes and tips. I cut them off at the downpipes. If you aren't near (likely), I do recommend Magnaflows - the thing sounded great with them. I changed mine out for the CC N11 - fit like a glove, ezpz, but it's a system for stock manifolds. Best, Paul
Old Mar 10, 2023 | 03:24 PM
gkull's Avatar
gkull
These are 3 inch in and out. Cherry Bomb 88104CB Cherry Bomb Vortex Mufflers | Summit Racing
Old Mar 11, 2023 | 11:54 AM
gkull's Avatar
gkull
My 4 inch chrome tips. going straight back it probably adds a mile or two to the top speed. Oh this exhaust system does get rid of the worthless spare and carrier weight.
Old Mar 12, 2023 | 10:16 AM
Cavu2u's Avatar
Cavu2u
I had this system built by a shop that specializes in custom systems in vintage cars. Well known in the San Diego area. Not cheap.
I went with the Borla S-Type, Their ATAKs are a little too much for me and the cul de sac I live in.
An exhaust system reminds you of how much you invested in it EVERY TIME you fire up the engine. You therefore want to avoid skimping on it. Magnaflows are good too. My only suggestion is Don't be cheap.
Steve
system removed for TH400 to M20 swap.
Old Mar 20, 2023 | 01:43 PM
pedalmore's Avatar
pedalmore
I too am exploring exhaust systems. At the moment, I need to replace mufflers and wondered how loud N11 is relative to Magnaflow.
However, it is also tempting to replace the whole system, headers included as the prior owner connected the AIR pump with welded tubes to the topside of the headers. Hard to tell if current headers are Hooker Super Comps, but bends look like the 1 7/8" models. For Hooker Super Comps, can installation be done with engine in car? Do they get installed from the bottom or top?
To C3 exhaust recommendations
Old Mar 20, 2023 | 06:30 PM
Cavu2u's Avatar
Cavu2u
For the SBC, from the underside was the only way for the ceramic Blackjack headers to go in my '73, including a dimple in the #4 tube to clear the Idler Arm bolt.
Steve
Old Dec 22, 2025 | 06:43 AM
WaltertheCat's Avatar
WaltertheCat
Originally Posted by Richard Daugird
Sidepipes!
Throw away power or accept a noise level that is "open" exhaust loud is an unnecessary trade off. With an under car system you can get both an acceptable sound and keep the power you've built into an engine. Insert mufflers are the absolute worst when it comes to killing torque and horse power. The great irony of side pipes: They look 'racy" but they are the exact opposite on street cars that can't run wide open exhaust without deafening you and collecting tickets.
Old Dec 22, 2025 | 06:51 AM
WaltertheCat
Jebby
They do an inexplicable accommodation for the e brake cable. Hard to overstate how crazy it is. Pypes mandrel bends their 2.5 inch tubes yet effectively destroys flow with a notch cut into the tubes for e brake cable clearance. When you see it....... it's more than just a head scratcher. It's more of a, "This is as serious contender for stupidest thing I've ever seen!".
