Over ride Bracket Under Dash
Old Mar 19, 2023 | 09:46 AM
76yellow's Avatar
76yellow
Default Over ride Bracket Under Dash
Hoping to put my 68 left dash pad back in today. Looking how the wiper over ride switch bracket mounts to the bottom of the dash pad, it wouldn't be grounded. Wouldn't it need to be grounded for the wiper over ride switch to function ?
Old Mar 19, 2023 | 03:49 PM
Mooser's Avatar
Mooser
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxx
M
Last edited by Mooser; Mar 19, 2023 at 05:36 PM. Reason: Totally wrong answer, my apologies
Old Mar 19, 2023 | 05:28 PM
Bandit54's Avatar
Bandit54
A correct switch on a ‘68 only has one terminal, the switch mount needs to be grounded there should be a ground wire in the wiring harness.
Old Mar 19, 2023 | 05:36 PM
Mooser's Avatar
Mooser
Holy cow. I never, ever would have expected them to run the ground through the switch itself. even the schematic looked like it went through. 68 was really an experiment
M
Old Mar 19, 2023 | 07:18 PM
76yellow's Avatar
76yellow
OK....Thanks Bandit. I'm using a toggle switch so I will just ground one terminal !
Old Mar 19, 2023 | 07:58 PM
Bandit54's Avatar
Bandit54
69 and later used a two terminal switch which made the groundings of the switch better.
To Over ride Bracket Under Dash
