1971 Base PCV Routing
Old Mar 20, 2023 | 08:49 AM
Gioviannia90's Avatar
Gioviannia90
Default 1971 Base PCV Routing
I am putting the vapor canister back on the car, was removed by previous owner. I am scratching my head on this T fitting that goes on top of the pcv and connects the the carb on ones side and canister on other. Below is what am example from Alan 71. I ordered the T fitting and I do not see how this will work, pcv end is too small. Does anyone know the pn for the correct fitting, I can't find it anywhere.
Old Mar 20, 2023 | 10:30 AM
71 Green 454's Avatar
71 Green 454
https://www.stockwiseauto.com/acdelc...hoCImQQAvD_BwE
Old Mar 20, 2023 | 10:58 AM
Gioviannia90
Originally Posted by 71 Green 454
That's it! Thank you so much, this was impossible to find searching for some reason!
Old Mar 20, 2023 | 11:00 AM
MelWff's Avatar
MelWff
it might be discontinued so grab it .
Old Mar 20, 2023 | 11:06 AM
sunflower 1972's Avatar
sunflower 1972
Here's what I did:
Standard Motor Products V210 PCV Valve
My 72 uses the same type of PCV setup as 1971 and I also needed a new tee. I found this PCV valve for a 1982 C3.
To 1971 Base PCV Routing
