1971 SBC Rebuild
1971 SBC Rebuild
Hi all,
Decided to rebuild stock 350, auto c/w shift kit, stock stall converter, 3.08, Edelbrock intake and 650cfm carb, HEI, headers. This is an around town daily driver, not a race car nor garage queen~looking for a bit more performance.
thinking about installing GM 19331470 SmallPort Vortec heads along with normal machining/new pistons etc. versus rebuilding original heads. Are these new heads worth the cost? Not sure, but expect small overbore.
Any cam recommendations, roller, etc? Local support has suggested an RV type cam. I used a Crane HT284 in another century, worked okay.
Open to all suggestions. Oh, small, very small, possibility going to 200/400 r type trans inn future. Depending on Finance & Approval Dept.
Thanks,
Finest
Thanks,
Finest
For the money I’d at least consider edelbrock estreet heads, part 5089. You could reuse your current intake as well. I’m pretty sure, vortec style heads require a different intake.
64cc heads with flat top pistons would put you around 10:1 CR and with a moderate cam, it’d be a noticeable improvement in performance
Thought about them, bit concerned about aluminium. Will investigate. Good point about fitment of intake. Another issue, we're outside of Toronto. Sometimes warranty for stuff like this in far, far away land is difficult. The Gm heads are sourced from Canadian dealer and warranty is everywhere.
Really appreciate your comments, thanks.
finest
finest
Received 4,678 Likes
Cruise-In VIII Veteran
Why would you be concerned over the far superior Aluminium heads???
just don't get that.
Your in Canada. And afraid of being in far Away land for warranty issues???
I am in Australia. I run Edelbrock heads.
1971 350 Rebuild
Now seriously considering Edelbrock 5089 heads. Any suggestions for cam? Would like a bit of lumpy idle, but wan't to keep factory THD400 stall.
suggestions?
Thanks, Finest
suggestions?
Thanks, Finest
I would look for something around .47 lift and a 270ish duration. I’m sure someone on this forum knows a cam that is around that.
5089 heads are max .55 lift.
also, just more for you to think about, if you switch to aluminum heads you need longer/hardened push rods. Idk if this is true for vortec heads.
edelbrock part 9629 are the recommended push rods for 5089 heads.
The majority of people here will say switch to roller. I like flat tappet. Maybe it’s because I’ve used them for years and years and never had an issue. I am not knowledgeable on roller swaps or recommended specs for roller cams, but someone will probably chime in.
Hey, another Canadian. I'm just down the highway a bit. Aluminum heads are a nice upgrade. Other than cost its pretty much all upside. I haven't built many motors but went roller lifters on the couple I have built. We used the comp retro roller kits. The roller cams can open quicker, so you can get more flow without having to have a ton of overlap. We built a 427 BBC and used a Comp Thumpr cam. It made decent power, very streetable but it sounded awesome. I wouldn't hesitate to use a cam out of that series again. I'm by no means an expert so take it for what its worth.
In my opinion, edelbrock doesn’t offer a cam that’s just right. The performer is too small, and the torker plus is too big(I run torker plus but I do a lot of drag racing, and I have a high stall converter)
