1980 Air conditioning
Old Mar 27, 2023 | 11:24 AM
joserpaq's Avatar
joserpaq
Default 1980 Air conditioning
Hello All,
I have a 1980 C3 that was converted to convertible before I bought the car. That was one of the things I liked about it. That body style with the convertible tail and top from a 1974 C3. The issue is I live in Miami and altough it sits in the garage with the top down all the time when I do take a drive during the days from April to November it can get pretty hot. I understand that the top on this car is basically made to keep you dry and air tight so as I'm driving expecially on the highway I have warmer air from the outside coming in. I replaced the compressor on the AC and it cools but the fan even on high really sucks and barely make a difference when compared to what my other cars blow on high.
Question is has anyone installed vintage AC unit? Will that blow much stronger and colder? I like the upgrade but it's almost $2k so I'm trying to decide if it's worth the trouble.
Old Mar 27, 2023 | 12:21 PM
speedreed8's Avatar
speedreed8
The evaporator core May be restricted with leaves and crap or etc. the fan motor may be weak or replacing the ground wire to a heavy gauge wire to the frame helps some also.
An additional shutoff valve to the heater core helps too
Old Mar 27, 2023 | 12:36 PM
mikepss's Avatar
mikepss
There is an upgrade to a C4 or C5 fan blower wheel done by many folks on this forum. Try searching for that. It seems simple enough but I admit I havent studied it in detail.
Old Mar 27, 2023 | 12:50 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Check temp at dash vent. It should be in the low 40 degree area. If not, something's amiss. I lived in Hollywood, Fl, when I had my '76 (T-Top obviously) and considered my a/c adequate +. Also be sure the outside air interior vent is closed when the a/c is on.
Old Mar 27, 2023 | 01:24 PM
C3Highway's Avatar
C3Highway
The first thing you must do is seal your cabin. Hot, humid Miami air flowing in will defeat even a properly running A/C system. Along the same line, confirm that your hot water shut-off valve is properly blocking hot coolant from reaching the heater core. These two preliminary factors are key to keeping your car cool.
Old Mar 27, 2023 | 01:28 PM
Jud Chapin's Avatar
Jud Chapin
Originally Posted by C3Highway
. Confirm that your hot water shut-off valve is properly blocking hot coolant from reaching the heater core. .
Good point. I disconnected mine as don't need no stinkin' heater in S. Fl.
To 1980 Air conditioning
