Well yesterday I installed my Viton Oringed caliper. Brakes bleed up fine.
Car is still on stands. 24 hours plus later. No brake fluid leaks. Any luck with the weather I'll get it down off the stands and test drive this weekend.
Lip seal calipers on mine and DOT 5 fluid. I've owned mine for 17.5 years and put about 40K miles on it. I have put 2 calipers on it in that time. Did DOT 5 cause my problem with either one? I have no idea, but I have no intention of flushing out the DOT 5. It was in the car when I bought it, and a month ago with my latest caliper replacement I didn't even consider replacing the DOT 5. Bright purple fluid to the RR caliper (the one I replaced) and was happy. I did have to bleed the brakes a couple of times to get a good pedal, but they work great now, as they did before the caliper needed replacing.
OK, let's start off with stating the obvious. There have been a whole lot of threads as of late concerning brakes. And the topic of DOT 5 fluid and the warnings on Corvette brake products not to use it.
Not long ago I put up a thread concerning a supposedly new caliper that came to me in poorly rebuilt condition. In that thread I posted up a photo of a O ring that came in a kit I purchased in a attempt to repair this garbage I paid good money for.
this O ring convertion kit came with what I feel where some really crappy looking O rings.
It was brought to light by a fellow former member that in the early days of these O ring convertions that the slight mould seam on the O ring would wear and then cause leaks. So the Corvette aftermarket sought out O rings with the seam offset.
My research seems to show that this is the approximate time the DOT 5 warnings came into being.
It seems that one rubber compound seems to work well with both DOT 3 / 4 and DOT 5. This is the EPDM rubber compound commonly used in brake parts throughout the automotive industry for approximately 50 years.
However, when special O rings where manufactured specifically for Corvette calipers. This is not the rubber compound that was used. Thus this crappy looking O ring that doesn't like DOT 5.
the rubber they use does play nice with DOT 3 and 4. But doesn't like DOT 5.
So I go into a major bearing and seal shop armed with a crappy O ring and ask them to get me a dozen of these in EPDM rubber. The guy looked through every book he had.
No dice. No one made a O ring in this size in this type of compound.
I am starting to see the problem here.
So, I says what compounds of rubber can you get this size O ring in?
the answer was 2 . One wasn't useful for a moving wear part whatsoever. The other was Viton. I know the Viton name as it is common with engine seals.
So, I did some more research.
Seams Viton isn't used in brake systems inspite of its good wear qualities in moving applications because it doesn't play well with DOT 3 and 4 brake fluid.
However, Viton plays very, very nice with silicone based fluids.
In fact the compound of choice with silicone based fluids.
So, I now have 4 , part number BS318V O rings that fit the pistons of a rear O ring conversion kit.
Now, using these O rings will absolutely not work with DOT 4. But according to everything I have read. Should work fine with DOT 5.
Now of course this is just for a rear caliper.
And this is a ongoing experiment. But I am fairly certain that running a Viton O ring in place of the supplied O rings with a O ring convertion kit should solve the problem.
As long as one doesn't change back to hydroscopic brake fluid.
Thought I'd open this up to discussion.
Me, I'm going to build one rear caliper and give it a trial.
Cause they are NOT going to make me change brake fluid.
(My parents didn't raise sheep).
I was reading through these messages, and unless I missed it, nobody stated the obvious. DOT 5 is silicone, and not compatible with anything petroleum based...DOT 3, 4. Mix the two and you could ruin your brakes. DOT 5 because it is silicone, it does not absorb water. It is used in my Harley-Davidson. I don't think once you use DOT 3,4 you can switch to DOT 5 because you can't get it all out of the system. The difference between DOT 3 and DOT 4 is DOT 4 has a higher boiling point.
Well, truth is, the two just don't mix. You can't mix the two. No they won't mix and form some kind of monster. That's total nonsense.
Harley stopped using DOT 5 from the factory about 20 years ago. So ,.... We have converted numerous newer Harley's to dot5. By just simply doing a standard brake fluid flush.
Absolutely none of them had there brakes ruined.
I converted my Corvette over to DOT 5 back in the 90's.
I'm still driving it. And believe it or not. It didn't ruin my brakes.
The ONLY issue is a certain company that supplies O Ring caliper parts for our C2 and C3 Corvette's decided that the parting seam on a standard O ring being right on the outer edge could possibly cause an issue.
So they have special O rings made that have the seam, / Parting line on a 30 degree (approximately) angle instead of the standard centered location.
Having these O rings made overseas, and to a price. They use a rubber that is fine for DOT 4, but not 5 as using the good rubber perhaps costs more?
However, the main reason I wanted to jump back in here is to try to keep things factual. Hard to say or guess how many hundreds of thousands of vehicles have been converted over to DOT 5 brake fluid. I know it's extremely popular in the old car hobby in general with seldom used cars. And also extremely popular with motorcycles which are also seldom used.
Add into that the boiling point of DOT 5 is higher still than Dot4. And with all those hundreds of thousands of vehicles out there, I personally have never heard of anyone's brakes being ruined. I have heard nonsense rumours. But never once seen anything of the sort.
Of course as a professional mechanic working 6 days a week for 50 years on DOT 5 equipped vehicles, what do I know.
When I first rebuilt my four calipers I switched to the O-ring type seal and had great luck with them. After rebuilding the system I then put in the DOT 5 brake fluid and drove it for a few months. The braking system seemed to need to be "warmed" up before the pedal feel was the same. The brake pedal was different when the system was cool.
The switch from DOT 3 or 4 to DOT 5 was more than just a "simple fluid change". It changed the way the brakes feel while driving them. After a period of time I went and dumped the DOT 5 brake fluid in favor of DOT 4. After releasing the DOT 5 I went and ran through several quarts of some type of alcohol that was sold to me for this purpose flushing the lines and calipers. Then I filled the system with the DOT 4 and bled the brakes, fortunately for me, the brakes came back to the normal feeling system I was used to.
My 1984 Yamaha RZ 350 also has DOT 5 in the triple discs on my 350cc monster.... It also has EVANS NPG in the radiator...
I've seen you comment on this forum before about a different "Feel" in your brakes at different temps with Dot5.
personally. I think that's all in your head.
DOT 5 brake fluid is indeed more compressible than DOT 3 / 4 /5.1, but I doubt you would be able to feel the difference with your foot.
Perhaps DOT 5 fluid has a propensity to entrain micro-air bubbles if the hydraulic system is not bled thoroughly, resulting in a different brake pedal feel compared to glycol-based fluids.
Of course you can get rid of the Dot 3 or 4. I push out what I can with my $70 amazon pressure bleeder, add Dot 5 silicone and start the pressure bleeding process.
You are done when you get pure purple fluid at each corner with no air bubbles.
If you don't have working o-rings and other rubber parts in your brakes, they won't work. Bad seals and o-rings ruin your brakes.
Absolutely, and if you read through all of this you would have seen that back in April of 23 I changed out those cheap O rings from the manufacturer of the ORing caliper kits with Viton ORing's.
That's 2 years ago.
My car still stops hard and straight and no leaks.
And yes, DOT 5 brake fluid.
And I've run DOT 5 in my Corvette for about 30 years now all up. On the street and a few track days. Hot, cold, whatever. I find it performs perfectly. I would say brake pads can be sensitive to heat. But DOT 5 has a much greater usable temperature range than DOT4.
Thanks for the research into these ridiculous Dot 5 claims. I have a 67 Chevlle using Dot 5.
I've never seen a good o-ring with any "parting seam." Where do you get these cheap orings with a parting seam on the OD ?
Dorman says that their rebuild kits for brake calipers are made from EPDM rubber and compatible with Dot 5 fluid.
I pulled up their kit for 1st gen Camaros and 65-82 Corvettes and there was nothing in the specs that said they were EPDM, so I emailed their tech support and explained the issue and asked if they could verify that their kits are EPDM and ok with Dot 5.
Hopefully they will get back to me soon and i'll let everyone know.
Then the question : If Dorman has rebuild kits ok with Dot 5, what excuse will these Corvette vendors use now ?
DOT 3, 4, and 5.1 are not petroleum-based; they are glycol-ether formulations. Additionally, they are all hygroscopic, which means they readily absorb moisture, something petroleum products do not do.
As others have replied, silicone 5 and 3,4,5.1 will not mix in the slightest. They just don't react with each other, so any remaining old fluid will just end up being pushed out during flushing.
I saw the Dorman master cylinder rebuild kit at Rock Auto. It says EDPM in the description AND it includes BOTH pistons. In the past, nobody else had the front piston as far as I know.
I've been dealing with a leak in a 66 Kelsey Hayes proportioning valve using DOT 5. The prop valve was rebuilt by White Post and they don't warranty when using DOT 5. If you're familiar with this prop valve, there is a 1" o-ring in the back held in place with a plate and c clip. A few years after the rebuild I noticed a little fluid had leaked out over the winter. I pulled the valve apart and bought a few different size EPDM orings and settled on the 119. Everything was fine for about 5 years and this past winter the leak reappeared. I had to buy the orings in bulk so I had lots of extras to experiment with.
The new o-ring had a cross section of 0.1070"
The leaky o-ring I removed had a cross section of 0.0960" (started at 0.1070")
So did it compress over time or did the DOT 5 shrink it? I need the o-ring to not shrink and if it swells a little that's fine based on its location and purpose.
Here's some interesting test results:
#1 - soaked with Blaster silicone spray and swelled from 0.1070" to 0.1285" I later dropped it into DOT 5 fluid and it shrunk back to 0.1185" and after a few weeks 0.1065"
#2 - soaked in motor oil and it swelled to 0.1180". I later dropped it into DOT5 and it shrunk to 0.1130" and after a few weeks stayed there
#3 - soaked in DOT 3 and it stayed at 0.1070" for weeks
#4 - soaked in DOT 5 and has gradually shrunk over a month from 0.1070" to 0.1020"
#5 - dropped the DOT 3 oring into DOT5 tonight to see if shrinks or retains the original cross section
For my particular use case, I need something that doesn't shrink with DOT5 over time and my guess is that is one of the reasons places like CSSB and White Post don't warranty parts used with DOT5
For what it's worth, the entire brake system was re-done 10 years ago with DOT5 in mind and there have been no other leaks
