The DOT 5 brake fluid conundrum.
Old Apr 11, 2026 | 12:09 AM
  #41
Bikespace's Avatar
Bikespace
O-rings are pretty cheap. Perhaps buy a few of the correct size, and repeat your experiment.
As @4-vettes suggested, Viton would be my suggestion, if I had to run DOT 5. Grok suggests EPDM, and sources a Corvette Forum posting. Even better, I'd suggest you carefully consider NOT using DOT 5.
https://www.corvetteforum.com/forums...id-please.html
Old Apr 11, 2026 | 08:59 AM
  #42
JC 1975's Avatar
JC 1975
I was experiencing fade when doing some “spirited” driving so I purchased a DOT 5.1 brake fluid. It is glycol based unlike DOT 5, but has a higher boiling point than DOT 4. I haven’t put it yet, because bleeding all the fluid out of the brakes will be a pain.
Old Apr 11, 2026 | 10:25 AM
  #43
Rebelyell's Avatar
Rebelyell
Originally Posted by JC 1975
I was experiencing fade when doing so “spirited” driving so I purchased a DOT 5.1 brake fluid. It is glycol based unlike DOT 5, but has a higher boiling point than DOT 4. I haven’t put it yet, because bleeding all the fluid out of the brakes will be a pain.
Do suggest a flush, BUT DOT 5.1 (NOT simply 5) is completely compatible And miscible with either DOT 3 Or DOT 4.
Old Apr 11, 2026 | 09:29 PM
  #44
sg66's Avatar
sg66
7th Gear
I'm going to get FDE and non-FDE Viton and run some tests. This is one of things I'll go deep into the weeds to figure out the best option that will work with DOT5. Already did a crash course today on compression set, FDE stretch limits and more.
I've been using DOT5 for close to 40 years and the only scenario I would 100% agree to not use it is for high altitudes. Back in the 80's I drove up the Mt Washington auto road and when I got to the top, the brake pedal went to the floor and had to be towed down the mountain. Once I got to the bottom the brakes were back to normal.
Something else I've learned from this is that the silicone in DOT5 does not react with EDPM the same way silicone lubricant does. One seems to shrink o-rings and the other makes them swell.
I'll be back in a few weeks with Viton findings
Old Apr 29, 2026 | 11:04 PM
  #45
sg66's Avatar
sg66
7th Gear
I've had a few weeks to do lots of research and compare Viton and EPDM and concluded that EPDM o-ring on the rear cap of the Kelsey Hayes prop valve failed over time for two reasons:
  1. DOT 5 causes EPDM to shrink. A new -119 o-ring has an O.D. of 1.1540" when installed on the rear cap. The leaking o-ring, 4-5 years old had shrunk to 1.1270" O.D. The cross section of the o-ring shrunk ~0.01". These don't sound like much but together they are enough to let fluid leak past the rear cap.
  2. EPDM "compression set" compounds the shrinkage problem. When compressed for a period of time, EPDM is more prone than Viton to retain its compressed state where Viton is more likely to bounce back. The o-ring in the prop valve is under constant pressure by the internal spring used for adjusting brake pressure so while it's shrinking, it's not bouncing back as much to fill the void.
I had to get more brake fluid anyway and got some of this because they claim it's compatible with EPDM. https://maximausa.com/products/dot-5-brake-fluid
I don't know what their definition of compatible is but new EPDM o-rings shrank from 1.1540 to 1.1435 after 2 weeks, the same as the other fluid I had. Viton didn't change at all.
By the way, the EPDM o-ring I started soaking in DOT3 over a month ago hasn't shrunk at all.
So that's it, now I understand why many places don't recommend or warranty brake components when using DOT5
If you're interested in learning more about o-rings than you ever wanted to:
Old Apr 30, 2026 | 04:34 AM
  #46
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
And yet my prop valve is original to the car. And I've been running DOT 5 for about 30 years. With zero leaks or issues.
Old Apr 30, 2026 | 07:59 AM
  #47
sg66's Avatar
sg66
7th Gear
When you switched to DOT5, did you flush everything and reuse the original o-ring? I wonder if DOT3 over time had permeated the o-ring helping it resist the effects of DOT5? I just went back and checked an EPDM o-ring from my original testing that had first soaked in DOT 3 for about 3 weeks with no change and then dropped into some DOT 5 for 3 weeks. It did shrink a little to 1.1450 O.D. which wasn't as much as a new one did in less time. Granted this doesn't take into account years of exposure, heat cycles, pressure etc. but does lead me to believe that rubber exposed to DOT3 might be more resistant to the effects of DOT5.
For what it's worth, my prop valve had been rebuilt with a fresh o-ring. Anyhow I'm feeling good about the Viton, thanks for the tip.
Looks like some similar testing happened over here https://www.corvetteforum.com/forums...ake-fluid.html
