Power Steering help
Old Apr 26, 2023 | 04:11 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Originally Posted by Pbal
I think I see what you're saying now. As I adjust the rod balance, make sure it ends up at the exact length where it will be mounted. I'm headed to the garage right now to work on it some more, I'll let you know how it goes - thanks.
by loosening the lock nut you can turn the entire valve unit to lengthen or shorten
Old Apr 27, 2023 | 04:11 PM
Pbal's Avatar
Pbal
Cruising
My thanks to all of you who have contributed thoughts and ideas here. Unfortunately, nothing has worked, and I can only conclude that the control valve is bad, so I'll be sending it back for replacement.
Old Apr 27, 2023 | 07:57 PM
interpon's Avatar
interpon
good luck..if you want to try again diy..here is the advice i got, still leak free.
https://www.corvetteforum.com/forums...-question.html
the kit is like 12 bucks
Old Apr 28, 2023 | 06:39 PM
Pbal's Avatar
Pbal
Cruising
That's a good thread, a lot of info there. It has inspired me to take another shot at my original PSCV, which I believe it the right thing to do, so today I removed and returned the bad valve. My problem now is that my personal schedule won't allow me to get back to this until about mid-May, but I'll be in a better state of mind about it by then.
