Check Engine Light Code 12
Old May 22, 2023 | 10:25 AM
rfscholl's Avatar
rfscholl
7th Gear
Default Check Engine Light Code 12
In my '82, I can go for a 5-10 mile ride which takes me up and down hills with no problems. Whenever I come to the end of the ride where I'm not really on the gas any more, like pulling back into my driveway or into a parking lot, the CEL comes on. It's back off once I restart the car, or if I leave it running and start going again it goes off. I checked the code using the blink method and got a 12. A bit of googling and I found a post that says code 12 is everything normal. Should I try to clear the code and then see what happens?
Thanks!
Old May 22, 2023 | 10:54 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
12 flashes 3 times before codes flash,3 times for each code
Old May 23, 2023 | 09:46 AM
rfscholl's Avatar
rfscholl
7th Gear
I forgot about that. I tried again, and it just keeps flashing the 12. I let it go six times. Does code 12 mean anything with those symptoms? Thanks!
Old May 23, 2023 | 09:57 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I remember times like that.
hated counting blinks.
book drove me crazy.
try and get the light on paying attention to conditions and repeat.
wild guess,, temp sensor to ecm.
To Check Engine Light Code 12
