Replacing the flashers
Old Jun 10, 2023 | 09:43 AM
cottoneg's Avatar
cottoneg
Default Replacing the flashers
I am going to try LED lights for the rear and possibly the front to avoid accidents. In my daily driver, I have been hit 3 times when I stop either due to traffic on the LIE or red lights. People just do not seem to pay attention anymore.
Anyway, to my question. I have been told by a member on the board “You will need to replace the flashers- both the hazard and turn signal one. GM changed the polarity (swapped the wires around) of the flashed I think in the mid 80s- so not all flashers are created equal.” This is the one I recommend- as the polarity doesn't matter. Plug it in and ground the wire-rather than worry about the polarity.
https://www.napaonline.com/en/p/NF_EL12L1
Getting the flasher will be easy as my son works at NAPA.
In a 1969 Corvette, where are the flasher located? Will I have to remove the dash?
Old Jun 10, 2023 | 11:11 AM
MelWff's Avatar
MelWff
One flasher in fuse box, one under passenger side dash which does not require dash removal, just reach for it.
Old Jun 10, 2023 | 12:05 PM
Barry's70LT1's Avatar
Barry's70LT1
I converted to very bright LEDs on the rear, and 2357 (Looks like a 1157 - only brighter) incandescent in the front.
Needed a new electronic flasher for signals, however the original hazard flasher worked fine.
Old Jun 10, 2023 | 12:55 PM
cottoneg's Avatar
cottoneg
Thank you gentlemen. One follow up question. The flasher in fuse box is for signal or hazard?
Old Jun 10, 2023 | 01:02 PM
Barry's70LT1
Flasher in fuse box = Hazard
Old Jun 11, 2023 | 08:02 AM
cottoneg's Avatar
cottoneg
The members here are the best.
Old Jun 12, 2023 | 11:58 AM
cottoneg's Avatar
cottoneg
One last question.
At Flasher - Turn Signal NF EL12L1 | Buy Online - NAPA Auto Parts (napaonline.com) is says Flasher - Turn Signal. Is the hazard flasher the same? In other words, can I buy two of the NF EL12L1 for both the flasher and turn signal???
To Replacing the flashers
