Carburetor tuning
I’d wait to get some input from Jebby or some guys that know carbs better than me but I’d be looking at moving up to a 8.5 possibly 9.5 valve. In short the power valve is kinda like a third jet that lets fuel into the carb when vacuum falls below the rated number of inches IE a 8.5 valve adds fuel sooner than a 6.5 on accel/cruising. Conversely though you might need to change up your accelerator pump cam or squirters. The “lean pop” your hearing could actually be a rich pop of you have an exhaust leak. An AF meter would be helpful here.
Use Street
CFM 650
High Speed Air Bleed 28/28
Idle Air Bleed Size 70;70
Primary Main Jet 70
Primary Power Valve 6.5
Primary Pump Nozzle Size 31
Mechanical Secondary
Main Jet 74
Secondary Pump Nozzle Size 31
Kossuth may have a good point. A lean part throttle bog could be the power valve setting. My LT-1 idled at 10.5" vac so I ran a 6.5 " power valve. And that's the PV you have now. You probably need higher.
The way you can tune a power valve is with a vacuum gauge. You have one, so get a long hose and have it inside the car while driving.
Write down your vac level at cruise speed. Then very slowly push the throttle down more (to eliminate the accel pump effect) and see what happens as you near / hit 6.5 and the installed power valve opens. Lean bog? Sudden pickup at 6.5? Lean AFR? Lean at what vac level? Then try a a 9.5 and repeat. The power valve # should be set at least several inches below your cruise vac. And not kick in too easy, only on moderately aggressive acceleration, like 1/2 throttle. IIRC 3-4-5 below is usually a good spot. There should be no surge, or hiccup, it should be a smooth increase in power as the throttle goes down to 5" vac. If your cruise is up around 16-18" you may want to go higher like a 10.5 or more. To keep it from going too rich too soon, use an AFR, or lean it out by lowering the PV#, until you get a bog, and then go higher until the bog just goes away.
Once you get the slow-throttle PV set to where the engine likes it, then you move on to the fast throttle Accel pump tuning.
All Holleys seem to like to be tuned to your cam-engine combo. There are tuning techniques to check each circuit if needed: Idle screws, main jets, PV, and accel pump.
I would run a hotter plug in those cyl's. ONLY the fouled cyl's.
take note those cyl's are worn and nothing but overhaul will fix.
unless the valve seals are the issue.
problem comes when cylinders allow too much oil and hotter plugs can't burn it off.
Like I told you many threads ago.
It is perfectly fine to have different heat range plugs in different cyl's.
nothing says all cyl's must have the same heat range.
Thanks for that. It's definitely the heads that are bad. When I first got it it would smoke pretty good for a few seconds every morning. Was definitely valve guides leaking over night soaking cylinders. I think those 2 were the worst. I Band-Aided it wth some positive valve seals and it greatly improved. But still burns about a litre per month, ish. Lol. Just trying to fix all this stuff then will probably rebuild it in near future. Finally got it running real good . We'll see how fouled the plugs are in a couple weeks testing it out. Been putting 20/50 in it for now, makes a huge difference in oil consumption. Motors tired. Can hear a bit of timing chain rattle too, so it's due. Actually torn which way you go. If I rebuild this motor I can do it myself. But I know a builder that will build me a high rpm 400ish hp 350 with aluminum head for 4500 Canadian. Cost me about 1000 to rebuild this one myself. Not sure which I'll do. Money will probably settle that one. I'll either have enough for the good motor or not. Just did my 351m so a bit tight right now. It was pricey being a rare motor and upgrading it to efi and bigger cam etc. Efi was expensive. Mainly the residuals like fuel tanks, pumps, filters ,lines etc. I actually have another efi set up for this motor(850cfm one) but didn't use it because I'm having a tough time learning how to tune them. Self learn is pretty basic. Anyway. Will do the plugs after I see what happens on these adjustments. Think I got it best it's gonna get.
