Question about Catch can location..
60
keep in mind that anything you put in the hose is a restriction
so on the vent side of the system, a restriction will raise crankcase pressure during load, and increase crankcase vacuum during part throttle
on the return side of the system, you must retain pcv control, unregulated vacuum application to the crankcase is not good
we have all of this figured out, and have many great options for any power level
we find most oil separators fall into the 40% efficiency range where ours are 70+
happy to help, please do not hesitate to contact
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
